mattocs Posted June 23, 2004 Share Posted June 23, 2004 So yesterday my cruise control stoped working...the light comes on when I press the botton...but it does not let me set a speed or accelarate. Could is be a fuse or something with the brakes (making it think i'm applying the brakes) 1996 Outback...anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Hocrest Posted June 23, 2004 Share Posted June 23, 2004 4 options--- 1st Look at the trottle, there are two cable to pull it... One goes through the firewall to the loud pedal, the other goes to a vacum canister in the engine bay, just under the driver's side windshield wiper. Check out the vacum hose attached to the other side of that canister, make sure it is on tight, mabe use a wire tie/clamp to be sure it is. 2nd Another issue may be dirty contacts in the switch on the steering wheel, shoot some contact cleaner in there and work the crap out of that switch to clean it out. 3rd Auto or 5 speed, if 5 speed it could be the switch on the clutch pedal, on one of my old wagons, I had to hold the pedal up with my foot to use the CC. 4th Could be the brake switch like you said Quote Link to comment Share on other sites More sharing options...
mattocs Posted June 23, 2004 Author Share Posted June 23, 2004 It was working fine yesterday...then I was in a 35MPH area and wanted to use my CC because cops love to set up speed traps there because if there was no signs you'd think it was a 55MPH...so I was accelerating and setting speed a whole lot with my CC lever...then later...it didn't work. I'll check out everything and make sure it looks good. Yes, it is a 5 speed. Quote Link to comment Share on other sites More sharing options...
mattocs Posted June 23, 2004 Author Share Posted June 23, 2004 I looked at everything and it seemed to be ok. The brakes and clutch come up all the way...so I dunno. Anyone know how much it would cost to get it fixed? I don't know how long I can go without cruise control. :-/ Quote Link to comment Share on other sites More sharing options...
mattocs Posted June 24, 2004 Author Share Posted June 24, 2004 Contact fluid...where could I get that? Radio Shack or something? Quote Link to comment Share on other sites More sharing options...
Hocrest Posted June 24, 2004 Share Posted June 24, 2004 Contact fluid...where could I get that? Radio Shack or something? RS, other independant electonic shops, Autozone, Napa, etc. Just make sure it is designed for electronics... Quote Link to comment Share on other sites More sharing options...
