oil feed to turbo custom line material?
jono
I went to a hose joint to ask about a custom oil supply line to be made from oil pump to turbo banjo for my ea81 idea
They suggested a banjo on the end of teflon hose encased in stainless steel braiding. Said teflon is good for up to 200 degrees C
OK oil temp should bnever get that hot, but surely the turbo core the banjo bolts into gets hotter than 200, like triple ?
I reckon it might fail, so queried and got the "I'm a fitter and turner, not a mechanic" reply
What have others done for custom turbo feed pipes other than metal ? I have seen an EJ turbo in a beetle and he had what looked like steel braided something to turbo with a junction for oil pressure switch
Did not ask at the time did I ?
thanks, and now I am awake it has become obvious - brake hoses can have a banjo bolt "eye"
Wondering if anyone has found a source for oil pressure from the front of the EA81 head as in the way EA82T are fed from the rear of the head so a banjo and some copper washers can be employed.
