Loud Power Steering Pump
17 replies to this topic
#1 Naked Buell
Naked Buell
    USMB Regular
  • 441 posts
  • Evans, WA
Posted 08 January 2018 - 09:56 AM
Hey guys. Noticed on my wife's 07 impreza that it sounds like I have a Ford power steering pump on the Subie.
I got the car with 24,000 miles and it is now at 145,000. Is it time to replace it??
#2 brus brother
brus brother
    Subaru Master
  • 2,229 posts
  • Connecticut
Posted 08 January 2018 - 10:10 AM
Fluid level? Any leaks?
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,092 posts
  • East Coast
Posted 08 January 2018 - 10:38 AM
It’s usually not the pump but air getting into it.
Have you checked the fluid level?
Any leaks?
It’s often an oring, if yours has an oring between the pump and reservoir. Is your reservoir on top of the pump or off to the side?
Look for leaks around the hoses attached to the pump. Replace any that are wet.
Some EJ engines (I forget which years have this set up) have a serpentine belt cover that needs properly installed as well or it pulls on the lines enough to cause noise. If this started after a belt change or some other front end work then check the serpentine belt cover. Though it’s been awhile so I forget which EJ engines this situation applies too.
Edited by idosubaru, 08 January 2018 - 10:39 AM.
#4 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,984 posts
  • Texas
Posted 08 January 2018 - 11:26 AM
look in the PS tank for bubbles while idling - you may need to pull the intake snorkel off and have a helper turn the wheel.
if you have bubbles (ok, one or 2 every few seconds from splashing is fine) you need to do as said above, stop air from being sucked in.
however, if the evidence points to a bad pump, they are known to be very robust parts and you can save some $$ by swapping in a pump from a wreck. car-part.com or maybe LKQ
#5 Naked Buell
Naked Buell
    USMB Regular
  • 441 posts
  • Evans, WA
Posted 08 January 2018 - 02:22 PM
I have no leaks, fluid level right on the money. It is original P.S. pump.
#6 idosubaru
idosubaru
  • 24,092 posts
  • East Coast
Posted 08 January 2018 - 03:04 PM
the issue i mentioned is 00-04 related, so not yours.
1.  look for bubbles after you've significantly heard the noise
2.  change the fluid?
3.  replace orings/hoses close to the pump - they don't have to leak, they simply suck in air.
Subaru power steering failure is rare, it's common to replace one and still have symptoms because people swear it's gotta be the pump.
That said - used pumps are cheap since they never fail there's zero demand.  www.car-part.com, ebay, etc.
#7 1 Lucky Texan
1 Lucky Texan
  • 7,984 posts
  • Texas
Posted 08 January 2018 - 03:13 PM
unless severe enough to foam fluid out of the tank, it won't leak fluid OUT, it sucks air IN.
look in the tank while the car is making the noise. On some tanks it's tricky, you have to get your eye right done to the top of the tank.
I had to do the o-ring replacement on my 06 WRX last year. noise and 'notchy-feeling' steering.
Edited by 1 Lucky Texan, 08 January 2018 - 03:15 PM.
#8 Naked Buell
Naked Buell
    USMB Regular
  • 441 posts
  • Evans, WA
Posted 09 January 2018 - 08:17 PM
Is there a part number for the o-rings you guys are mentioning??
After you said "air" it makes sense.
#9 idosubaru
idosubaru
  • 24,092 posts
  • East Coast
Posted 09 January 2018 - 08:21 PM
I’ve only ever matched them up, don’t know.
#10 1 Lucky Texan
1 Lucky Texan
  • 7,984 posts
  • Texas
Posted 10 January 2018 - 09:00 AM
might be able to get a part number digging around at www.opposedforces.com or by calling a dealer I guess?
#11 Numbchux
Numbchux
    EJ conversion addict
  • 6,889 posts
  • Saginaw, MN
Posted 10 January 2018 - 09:18 AM
I just did that O ring on our Outback, old one was as hard as plastic.
MSRP on it from the dealer was less than $2. That and a couple worm clamps on the suction hose seem to have solved my fluid aeration problem.
#12 Naked Buell
Naked Buell
    USMB Regular
  • 441 posts
  • Evans, WA
Posted 10 January 2018 - 11:11 AM
Cool guys. Thx. I will let you know what I find out.
#13 GeneralDisorder
GeneralDisorder
  • 22,048 posts
  • Portland
Posted 10 January 2018 - 12:05 PM
Get a new o-ring and suction hose. Should fix the problem. I use double Oetiker ear clamps on the pump elbow.
#14 Naked Buell
Naked Buell
    USMB Regular
  • 441 posts
  • Evans, WA
Posted 17 January 2018 - 11:22 PM
You wouldn't happen to know the exact size now would you???
#15 Gloyale
Gloyale
    It's a sickness
  • 10,916 posts
  • Corvallis, OR PNW
Posted 18 January 2018 - 02:22 PM
subaru sells a whole kit to renew the pumps.  about $40 bucks for seals and o-ring and a bearing.
#16 Numbchux
Numbchux
  • 6,889 posts
  • Saginaw, MN
Posted 18 January 2018 - 03:13 PM
I don't think any come with the bearing. And they stopped offering them around 2004
#17 Mike104
Mike104
    Subaru Fanatic!
  • 751 posts
  • N KY
Posted 18 January 2018 - 08:59 PM
The O-Ring PN for the Elbow fitting is 34439FG000
https://parts.subaru...G11-348-05.html
You may be able to remove the O-ring and take it to a parts store to match it rather than buying the $2 part from Subaru
Edited by Mike104, 18 January 2018 - 09:26 PM.
#18 GeneralDisorder
GeneralDisorder
  • 22,048 posts
  • Portland
Posted 18 January 2018 - 10:11 PM
2002 was the last year for reseal kits. They are no longer offered.
