05 Impreza Not Starting after Engine Install
4 replies to this topic
#1 steve56
steve56
    New User
  • 255 posts
  • Seattle USA
Posted 23 January 2018 - 04:58 PM
Reinstalled engine after doing head gaskets. Its turning over and getting fuel, but not starting. Haven't checked for spark yet  because dont have a helper to turn it over. The cruse control light is on and cooling fans are running with the key on.
Edited by steve56, 23 January 2018 - 05:18 PM.
#2 montana tom
montana tom
    Subaru Nut
  • 569 posts
  • trout creek montana
Posted 23 January 2018 - 05:20 PM
Make sure the large connectors at rear pass side are snapped together well.   Then check crank and cam sensors are connected.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,064 posts
  • Portland
Posted 23 January 2018 - 05:54 PM
Forgot to plug in coolant temp sensor. Pull codes.
#4 steve56
steve56
    New User
  • 255 posts
  • Seattle USA
Posted 23 January 2018 - 06:29 PM
First code is: coolant temp sensor circuit high voltage. Second code is: p0700 Transmission Control Malfunction
Great call. The coolant temp sensor was unplugged. Plugged it in and it started right up. Thank you.
Edited by steve56, 23 January 2018 - 07:11 PM.
#5 GeneralDisorder
GeneralDisorder
  • 22,064 posts
  • Portland
Posted 23 January 2018 - 07:13 PM
Yeah that will get ya every time. Glad I could help.
