paulcarlsen Posted January 26, 2018 Share Posted January 26, 2018 I think my center support bearing is wearing out (squeels, squeeks, etc). I've read how to replace them, but I have not been able to find the center support bearing. Any Ideas, suggestions, criticisms,etc would be much appreciated. Thank you very much! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 26, 2018 Share Posted January 26, 2018 Buy a used one and swap it out. All ER27s and EA82 MTs are the same and all the ATs are the same. Www.car-part.com A machine shop or driveline shop could probably rebuild it. If you can access the bearings you could try to use a needle fitting to inject the bearings with grease. That’s all that happens - the quarter century old grease is gone and degraded to clumpy clay. I’ve done it with quite a few other bearings but haven’t tried the carrier bearings yet. They go from nasty to feeling like new instantly. Quote Link to comment Share on other sites More sharing options...
