Best piston and rod combo for naturally aspirated EJ22
3 replies to this topic
#1 pro4
pro4
    Member
  • PipPip
  • 12 posts
  • boise id
Posted 13 February 2018 - 06:01 PM
Before I spend the bucks for my engine I thought I would post and get some advise to see if theres a better set up out there.
 I ran this for two races last year(hopefully picture loads) . Circle track car . It has to be a 2.2 . Homemade intake with 500 holley , escort distributor. Ran great for having 222,000 miles . Its time to build some HP. I would like to twist this to 8500 if need be. I called wiesco and they can make me some flat tops for 150-200.00 each which should get me close to 12:1 . I was going to purchase some rods , either Manley or Eagle I beams .
Anything I should watch out for? Maybe a different brand? less cost? Your input would be greatly appriciated before I go spend a chunk of change .
Picture didnt load (too big of file) and I dont know how to change  it
#2 wtdash
wtdash
    Subaru Nut
  • 1,603 posts
  • N. ID
Posted 13 February 2018 - 06:49 PM
Hi,
Sounds fun.
I'm NOT an engine builder/expert but FYI the stock rods and  crank are forged in the '90-'98 (maybe the '99-'01) EJ22e, from what I've read.
GL,
TD
#3 joomanburning
joomanburning
    Advanced Member
  • PipPipPip
  • 52 posts
  • Wellsville, KS
Posted 14 February 2018 - 06:09 AM
Grind them cams! Delta, Delta, Delta
#4 montana tom
montana tom
    Subaru Nut
  • 569 posts
  • trout creek montana
Posted 14 February 2018 - 10:40 AM
Ceramic coated piston's for sure.     Back in the mid 90's I ran an early 2.2 ,in a 1980 4wd hatchback . Bone stock other than modified intake 500 cfm holly and  I think it was a courier distributor, on a high bank dirt track  ... GREAT FUN  ... huge black hole for $  .I lost most of the  the time running against the 2500 ford 4cly.  I could blow by them in the corners "running low" they had to float up to the top. Then down the straightaway they blew by me...   I miss it !   Wish our track never shut down.
