My '87 XT AWD, mazda rotary swapped, Gambler.
flight_of_pain
The chassis started life as an '87 Subaru XT 4cyl turbo AWD. It was
the highest trim level available in that year, and the most aerodynamic
production car at the time. My dad bought it in the early 2000s and
daily drove it for 100,000Mi or so. It has been totaled out three times
by various insurance companies, and when the headgaskets went at 250K,
he parked it in a field. Last year i rescued it, and set about to build a
car I had been squirreling parts away for about 10 years.
How she came home:
https://imgur.com/S9Oytmk
https://imgur.com/O0mVLdl
Old motor out, new motor in:
https://imgur.com/Z9Oynhy
https://imgur.com/oqQADz1
Modifications were necessary...
https://imgur.com/ooJtLRn
https://imgur.com/LQTPCK3
https://imgur.com/cVrsqJW
Adapter plate to mount a Mazda rotary to a Subaru gearbox:
https://imgur.com/7SKQ95c
https://imgur.com/OdMZ5s7
Semi-finished, but running and gambler500'ing:
https://imgur.com/ZSDoHgN
https://imgur.com/ZmCATQK
https://imgur.com/r1hw5qJ
https://imgur.com/OLHiDYp
  • Like 2
Stock digidash was retained, and functions:
https://imgur.com/v7URe4c
https://imgur.com/DnMUo3W
Next step was a lift... the front got loyale struts, and ford tempo
springs, the rear is 2wd xt struts with 80s honda accord front springs.
This resulted in a net gain of over 6in vs the sacked out stock parts.
https://imgur.com/nSxp9eA
https://imgur.com/y4imUTQ
https://imgur.com/R5MIkmj
https://imgur.com/ehA36Z2
Added some bigger wheels and tires, redrilled 6 lug truck wheels (subaru's 4x140 pattern can go codswallop a rake...)
https://imgur.com/jSnS0OP
https://imgur.com/Et7ibh8
https://imgur.com/YMxP2kr
https://imgur.com/sQTKo63
https://imgur.com/vrh06gn
https://imgur.com/yRf9pca
Then we Gamble with it... 1st place at the North idaho gambler, and
fastest time of the day on day two of the Washington gambler.
https://imgur.com/Z9Y4Kw6
https://imgur.com/NQvE1B1
https://imgur.com/SCppDwO
  • Like 1
Works good...
Progress!
FC cas, and .96 hot side t04e. probably a 57 or 60 trim compressor, should be fine for 250-300hp.
https://imgur.com/vEROu8F
4x 550cc EV-14s, should support up to 280-300hp in fuel.
https://imgur.com/OEGdapE
Pile of Speeduinos... A v0.3 for the RXT, a v0.3 for a buddies subaru, and two NO2C boards for motorcycles.
https://imgur.com/Cz8pW9T
Some in car footage from the North Idaho Gambler. We averaged 38-42mph for the day.
Edited by flight_of_pain
  • Like 1
I bought the adapter plate and flywheel about a decade ago. It was a small batch casting, unknown manufacture. The flywheel is a subaru unit, redrilled to the mazda pattern and the center opened up to slip onto the mazda counterweight. Everything else is stock subaru parts. The australian Subarugears guys make a rotary adapter, but they want new $1000 for it last i saw.
There was a rotary-rx that was posted here a few times over the years, probably built at least 15 years ago.
IIRC, JWX bought it and swapped it back to an EA82t relatively recently.
I think the Subarugears adapter is designed for the EJ transmission, too (a better option, but an interesting difference).
Makes the purist in me cringed seeing the hood hacked up like that. But whatever, sweet build.
  • 2 weeks later...
What is the post Gambler fate of this vehicle?
We have run two gamblers in it so far, and I've been daily driving it for the last 6mo or so. It gets run hard at the ORV park at least once a month, and the only casualties so far are clutches. I took a bunch of footage the last run out at the ORV park, ill post it up as soon as I trim out all the fat.
Let me know if that thing ever gets parted out.  I've got cash-money with your name on it for the rotary bits...
HA! I spent 10 years acquiring the parts to make this shitheap happen. It wont be leaving my possession while I'm still breathing ;) I have a backup chassis in white, and after that i would probably move it all to a 1st gen imp. My close friend (drives a 323gtx) has been trying to convince me to pay one of the Chinese forges to replicate the adapter a dozen times. the rest of the parts are modified subaru.
  • Like 1
