4WD switch wiring help please with pics! 1991 Loyale
4wd switch wiring
2 replies to this topic
#1 Silas Cruse
Silas Cruse
    Advanced Member
  • PipPipPip
  • 96 posts
  • Dallas Oregon
Posted 18 February 2018 - 01:26 AM
1991 Loyale Wagon  4wd MT
So my 4wd switch has failed for the third time.  :banghead:
My local Junkyards, near Salem Oregon often have parts available. I want to try a different solution.
My plan to is to install a 3 way toggle in the dash as a replacement for the stick shift button.
And then choose an awesome replacement shift knob.
I have researched but not been able to find a diagram of this system.
I did find some 1988 Justy stuff but only the vacuum/mechanical, not the electrical.
Note: Direct vacuum to each diaphragm line does work and actuate the 4wd ,
I heard the clunk, and saw the green 4WD light on the dash.
I am looking for the wiring diagram.
I want to know this:
Switch wire   -3 - white , red, yellow
wire from firewall - 4 - blue, green/yellow, black, black (2) .
plug:plug to vacuum switches black black, white white.
vacuum switches 1 has 2 black , 1 has 2 white.
Attached File  20180217_162655.jpg   85.76K   3 downloads
Attached File  20180217_162719.jpg   103.21K   4 downloads
Attached File  20180217_162750.jpg   67.04K   3 downloads
#2 Gloyale
    It's a sickness
  • 10,720 posts
  • Corvallis, OR PNW
Posted 18 February 2018 - 01:27 PM
You need a single pole Double throw without a center off.
Basically both solenoids get one wire to ground each.  doesn't really matter which, you could test for continuity to determine which wires are which, or start from scratch and run your own.
Then the 2 other wires, one or the other should get 12v+ at any given time.
Check the wires inside for 12v+ with key on.  That is the supply, the other 2 are 12v+ out to either solenoid.
#3 Silas Cruse
Silas Cruse
    Advanced Member
  • PipPipPip
  • 96 posts
  • Dallas Oregon
Posted 18 February 2018 - 03:34 PM
OK i will do the tests.
