IAC valve question
2 replies to this topic
#1 brentlysubaru
    Advanced Member
  • PipPipPip
  • 46 posts
  • Salineville oh
Posted 23 February 2018 - 07:37 PM
I got a 96 impreza 2.2. I was getting a high idle every once in a while it was around 1100 rpm when idling. I changed the iac valve with a known good one. It actually looked like it was new. I was noticing once the valve was taken off there is a rubber insert in the intake. One had a metal plate behind it with slots in it and the other didn't have the metal plate on it was just the rubber insert. I left the plate off thinking it should give it better air flow. Car seems to run fine without it. What is the purpose of the metal plate?
#2 idosubaru
    Elite Master of the Subaru
  • 23,866 posts
  • East Coast
Posted 24 February 2018 - 08:45 AM
Probably a gasket. Can you post a picture?
If it’s running properly and the unit plugs in then it’s fine. The thing either vacuum leaks or doesn’t.
You’re positive it’s the IAC and not the EHR valve which has a distinctive metal plate as well right?
Edited by idosubaru, 24 February 2018 - 08:46 AM.
#3 brentlysubaru
    Advanced Member
  • PipPipPip
  • 46 posts
  • Salineville oh
Posted 24 February 2018 - 12:02 PM
I'm unable to post pics but I found one on eBay.
