jono Posted March 10, 2018 Share Posted March 10, 2018 Series 1 EA82 sensors are two wire. Series 2 are single wire. Has anyone used the single wires in a series 1 to replace the two white white sensor? Is one wire just an earth? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 10, 2018 Share Posted March 10, 2018 Do you have an FSM to look at? Quote Link to comment Share on other sites More sharing options...
jono Posted March 11, 2018 Author Share Posted March 11, 2018 you would think so hey ! Laziness asks for previous hexperience, guilty Quote Link to comment Share on other sites More sharing options...
jono Posted March 11, 2018 Author Share Posted March 11, 2018 Now, I recall why I asked - not entirely due to laziness. There is a limitation to what the manuals reveal once wires go inside the KCM of Series I It is two wires from sensor to box Need to add in words of description AND understand piezo, but its a bit like an O2 sensor that produces a small Voltage O2 sensors can be as simple as a single wire, as can be most modern knock sensors ? That would make one wire off the sensor an earth from the knock box, the other to carry Votage produced by the piezo. I do klnow that normal running the Series I produces 1.7V out of the KCM test wire and ramps up as high as 4.5V but doubt this is produced by the knock sensor piezo itself, but doubt is with little knowledge Now, think back to piezo bbq igniters, hws igniters, mozzy bite calmer downer gadgets Maybe it does produce such Votages or the KCM builds it up to an automotive computer ECU level At the moment I do not have a working Series I KCM circuit to work with. May just have to fit it up to my MONGREL, tap into and monitor both wires from the white two wire baby Quote Link to comment Share on other sites More sharing options...
jono Posted March 25, 2018 Author Share Posted March 25, 2018 where have all experts gone then ? I ordered one genuine(leaving a testicle as a deposit - Rock wanted both!! ) Only live once - or twice. Rather splurge now and get genuine, tinker later with cheap after market or new style Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 26, 2018 Share Posted March 26, 2018 Oh yeah ask away. I was wondering in case no one replied as it’s probably an uncommon need and situation. The few I’ve had fail I just swap in another use one laying around. Ask someone to mail you two of them or one of each or two of each and Have them also mail you a pigtail for it so can you can make an adapter for yours? I would think it’s easier to install a 2 wire into a 1 rather than the other way around. FSM would show where those wires lead and what they’re used for. Quote Link to comment Share on other sites More sharing options...
jono Posted March 26, 2018 Author Share Posted March 26, 2018 Yeah, Ido...FSM shows wires leading into a box of circuitry. I will liely make up a shielded connection, T in a test wire at same time sso I can monitor things. I have an EJ knock sensor or two, maybe even a Ford six one as well. Someone tells me if you see an EJ knock sensor with a crack it is a sign its been overheated. I know I have a cracked one. I am also thinking I will fit a knock sensor dizzy to my NA running 22 DBTDC @ 800 rpm idle as just starting to hear it ping at high revs in 3rd of five gears. The box is already in the car for turbo engine. Or braze up the ends of the advance slots in the dizzy for some old school tuning Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 26, 2018 Share Posted March 26, 2018 that's awesome you're willing to try that, good idea. Someone tells me if you see an EJ knock sensor with a crack it is a sign its been overheated. I know I have a cracked one. nah, they crack all the time. by far most common EJ sensor failure for all 20+ years of the existence of that engine. i have no idea how many i've seen crack. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 26, 2018 Share Posted March 26, 2018 or one could say they are prone to crack anyway and probably happens more often on overheated engines due to the additional stress. Quote Link to comment Share on other sites More sharing options...
jono Posted March 26, 2018 Author Share Posted March 26, 2018 Hope you are reading THIS Greg ! Quote Link to comment Share on other sites More sharing options...
