LosDiosDeVerde86 Posted April 6, 2018 Share Posted April 6, 2018 2010 Legacy 2.5i, CVT, 97k miles. This happened yesterday on a short drive. I pulled over and let it sit for about 5 minutes. When I turned it back on the VDC and Brake were still doing their thing but the AT Temp light was off. Called the wife to bring me my BlueDriver scanner before I continued to drive it and there were no codes. Started it back up after about 15 or 20 minutes and the lights were all off and have been off since. Any idea what those lights in that configuration are trying to tell me? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 6, 2018 Share Posted April 6, 2018 I had something like that once, turned out to be a dying car battery. One of the cells had gone bad. It still had enough power to run the starter to start the motor, but not enough voltage to run the instrument panel. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 6, 2018 Share Posted April 6, 2018 +1 power issue - check connections and battery and alternator output. if they come on again and you think power is fine, on older models you can just read the brake or AT codes and see what you got. i'm not sure how to do that, or if that's still an option, on a vehicle as new as yours. Quote Link to comment Share on other sites More sharing options...
