turboguzzi Posted April 11, 2018 Share Posted April 11, 2018 Oh well, my girlfriend's otherwise perfect 99' forester started doing that strange on off rumbling noise in tight turns... Lifted the wheels one at a time to do the torque test and yes, it grabs then releases, so 99.9% it's a viscous coupling gone. now for the ID issue, according to this well put together guide : https://www.alldrivesubaroo.com.au/gearbox/subaru-centre-differential/ i have a hard time knowing if i have the 91'-98' TY752 gerabox that uses the early type coupling or or the TY754, 755, 757, 758 1999 - current gearbox that uses the newer type coupling (scroll to middle of the page) the opposed forces PL even shows three options to the transfer case http://opposedforces.com/parts/forester/en_s10/type_1/manual_transmission/mt_transfer_and_extension/ Is there anyway to know from the vehicle ID what type of gearbox/coupling i need? VIN JF1SF5LJ4XGxxxxx shows it's an SF5 forester from late 99, any way to know for sure what coupling type should i look for? tnxs in advance! TG Quote Link to comment Share on other sites More sharing options...
matt167 Posted April 11, 2018 Share Posted April 11, 2018 transmission tag is on the bellhousing Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 11, 2018 Share Posted April 11, 2018 99 is a phase II transmission. You have to buy the complete center diff. They are right near $500. GD 1 Quote Link to comment Share on other sites More sharing options...
turboguzzi Posted April 11, 2018 Author Share Posted April 11, 2018 tnxs for the info guys. so number location would be as in the pic right? do i need to order other parts to do the job? havent seen a really good description of the work but sounds like its an on-the-car job. whats not clear to me is if all the transfer case needs to come off or if by just removing the end cover i can change the coupling tnxs again TG Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 11, 2018 Share Posted April 11, 2018 This is the part you need: https://parts.subaru.com/p/Subaru_1999_Forester-L-25L-MANUAL/CENTER-DIFFERENTIAL-ASSEMBLY/49248160/38913AA102.html And the gasket: https://parts.subaru.com/p/Subaru_1999_Forester-L-25L-MANUAL/GASKET-TRANSFER/49244588/33179AA030.html And yes you can replace the center diff by removing the rear cover only. GD 2 Quote Link to comment Share on other sites More sharing options...
turboguzzi Posted May 19, 2018 Author Share Posted May 19, 2018 hi guys well, at the end it turned out that it had the old style rebuildable coupling so i count myself lucky. Went to this super friendly small Subaru specialist that i know and it all cost around 500$ including coupling rebuild and labour, Regretfully for most, he is located near Lake Como in Italy, so of help only to italian subaroids, doubt if there many (or any...) of us here, but just in case: www.autoklaus.com i usually do all of my wrenching, but being on crutches following a motorcycle accident, just couldnt do it this time, would have been a bit of a stretch for me anyway.... tnxs again for your info 1 Quote Link to comment Share on other sites More sharing options...
