Crank end wobble ? 2.2 New Old Stock pulley ( balancer )
8 replies to this topic
#1 moosens
moosens
    Vintage Subathusiast
  • 2,022 posts
  • Bridgeport CT
Posted 26 April 2018 - 10:15 AM
1992 EJ22 - 312k miles
Just had this engine out last winter 2016/17. Needed clutch so I did a full timing and reseal - less headgaskets. When I sealed the oil pump to block I am sure the o ring stayed in place and I used “the right stuff” as a gasket maker. Very thin coating and I’ve done it before. Did not leak a drop for most of a year.
Now as of this winter:
Spews oil when full. Oil is at least partially coming from the oil pump area. Probably all from there and blowing back giving appearance of other leaks. Oil pan looks perfect. Heads look fine looking along the seams as best as I could see.
Crank pulley ( harmonic balancer ) was new Old Stock just a year or so back. Looking at it I’d say it is still fine and is just showing the wobble that the crank end has caused.
Time and weather have been tough since this occurred. So getting to verify without removing covers etc hasn’t happened. Just getting warm here now.
I’ve seen folks mention that the crank end can get soft and flex at 300k or so. True ? Because I’m thinking this is what’s happening.
Meanwhile like my brother asked , the crank itself seems fine , no inner noises from low end etc.
This car has been with me for 11 years now and I’ve put nearly 200k on it for $1500. Had 119k , now at 312k. It’s become a friend. Lol
Thanks for any help.
#2 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 26 April 2018 - 11:51 AM
 Wobble is likely in the pulley, not the crank.  I can't see the crank snout "softening" espescially since it has nearly zero force on it's end compared to the massive forces at the rod journals.   Might want to check that it hasn't moved on the keyway.
Gotta pull it to reseal the oil pump too.  Did you use the correct reinforced O-ring from subaru for the oil pump?
#3 moosens
moosens
  • 2,022 posts
  • Bridgeport CT
Posted 26 April 2018 - 03:35 PM
Yeah , I think they are blue , correct?
Hardened crank shouldn’t do that , I agree. Just that I know I saw it mentioned. Only force I could see would be if I massively cranked the accessory belts. Even still , doesn’t really seem possible.
I definitely buy at the dealer for all seals and most parts.
Just drive the car 100 miles today. Other than that lovely oil on exhaust smell the car is still plenty fine enough of a commuter/beater.
I’ll make time this weekend and find out what happened.
#4 moosens
moosens
  • 2,022 posts
  • Bridgeport CT
Posted 26 April 2018 - 03:41 PM
Side note.
Took my a/c tensioner pulley assy off to change out the bearing and found those three mounting bolts were 13mm heads and obvious hardware store shiny metal. That made me think “wtf did I do last winter”?
But I think that was my brother. Car was at his place during clutch job.
#5 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,105 posts
  • East Coast
Posted 26 April 2018 - 03:49 PM
Pulley.
Oil leaks like that suck, in your face everywhere and messy and noooow where did it come from?
You don’t drive backwards to work right?!
If its up front then pump seems likely - maybe just clean off all around the pump first and see if you can identify a leak and ignore the rest of the mess for now.
#6 moosens
moosens
  • 2,022 posts
  • Bridgeport CT
Posted 26 April 2018 - 03:55 PM
Lol , thanks
#7 GeneralDisorder
GeneralDisorder
  • 22,064 posts
  • Portland
Posted 27 April 2018 - 02:35 PM
I've seen more than one 2.2 with the #3 thrust that had excessive thrust play. Definitely check.
#8 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 27 April 2018 - 02:51 PM
Yeah especially on Manual trans models since the thrust journal takes the force of the clutch throwout bearing push against the PP.  at 317k that's seen alot of pushes.
#9 moosens
moosens
  • 2,022 posts
  • Bridgeport CT
Posted 27 April 2018 - 04:06 PM
Thanks guys. That’s plenty enough confirmation.
With my limited space and time to work I’m likely swapping out this 2.2 rather than tweak around an engine I know I sealed the dook out of just 16 months ago.
