Blowing oil out valve cover vent tube. Help
Having them cut back flat today. Idk what happened. I’ve torqued these heads a million times. Not sure what happened. Maybe just the quality of gasket. I had the felpro the first time, then i tried I think the brand was cometic or somthing. The metal shim type. What type of gasket material are the 2004 sti ones u reccomened?
Well I hooked up both together the control valve and the AOS. It’s a freakin complicated setup but man oh man does it work amazing. Now I’m working on a msd dis 2 ignition box to make my rev limiter higher.
Edited by Tireman28
