Zoltan Posted May 9, 2018 Share Posted May 9, 2018 Does anyone have any experience and or recomendation on an inexpensive timing belt kit for a 1999 ej22 and a 1998 DOCH EJ25. I am not in a rush as the cars are not my daily drivers. They are older cars and I do not want to spend the money on factory subaru parts, other than the water pump gasket and maybe the cam seals. I would just like to know if anyone knows of a kit that is inexpensive but seems to be good value. There seems so may to choose from on ebay, etc. Thanks for your time it is much appreciated. 4 Quote Link to comment Share on other sites More sharing options...
Bushwick Posted May 9, 2018 Share Posted May 9, 2018 Try one of the better brand names from Rockauto.com. and just get the belt, pulley, etc. Should be cheap enough and plenty of different price point (brands) to choose from. I'm not a fan of "new" car parts of ebay regardless of what others say, as it's most likely Chinese junk w/o the better name behind it. Quote Link to comment Share on other sites More sharing options...
mikec03 Posted May 9, 2018 Share Posted May 9, 2018 (edited) I think that the overwhelming belief is that the Aisin kit which includes the pump is the best. It's about $200. Edited May 9, 2018 by mikec03 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 9, 2018 Share Posted May 9, 2018 I'm not sure about a 99 EJ22, but the 'cheapest' kit for that 2.5 interference-engine is the one least likely to fail before the next belt service. Quote Link to comment Share on other sites More sharing options...
montana tom Posted May 9, 2018 Share Posted May 9, 2018 Both are interference motors. Almost guaranteed to bend the valves if the belt or idlers fail's early .... At the least go with aisin or mitsoboshi timing kit, you can skip the water pump unless yours is leaking. Same with cam & crank seals if they are not leaking DO NOT mess with them. 1 Quote Link to comment Share on other sites More sharing options...
moosens Posted May 9, 2018 Share Posted May 9, 2018 Don’t go with your subject title!!!! Spend the extra and keep rolling. Quote Link to comment Share on other sites More sharing options...
montana tom Posted May 9, 2018 Share Posted May 9, 2018 If you decide to go with a cheap one ... even with a name you know (likes Gates or dayco) INSPECT EVERY PART , some gates kits are made in usa... most are CHINA ! Not just the belt, every idler should be made in japan anything china made will fail sooner rather than later. If you install a china part and your motor dies well... You get what you pay for. 1 Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted May 12, 2018 Share Posted May 12, 2018 I have 98 obw. I installed a $120 ebay kit 10 years ago without any issue. This summer I will be doing the same job again. I will go with the Aisin kit this time around 1 Quote Link to comment Share on other sites More sharing options...
Mike104 Posted May 12, 2018 Share Posted May 12, 2018 I bought Koyo, NTN and NSK components from Japan on ebay/amazon to do my timing belt job. I mistakenly bought a Gates Chinese Junk Kit previously and don't want to risk it failing before the next scheduled change. 1 Quote Link to comment Share on other sites More sharing options...
montana tom Posted May 12, 2018 Share Posted May 12, 2018 This item # at Ebay is the timing kit I install on every car that comes thru the shop. $236.95 delivered Koyo ,ntn idlers mitsoboshi belt and in the box OE Subaru tensioner. Super fast delivery. If you want the same kit with a Subaru branded belt its item # is 200858175013 $279.89 delivered. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted May 12, 2018 Share Posted May 12, 2018 Recently had a moon light mechanic install a timing belt kit in my 08 Outback. I bought an Aisin kit through Amazon for about $278. All parts are Japanese manufactured. My mechanic told me all components in the kit were correct, except for the water pump. The kit pump was the wrong unit. I had him re-use the old water pump. I contacted Amazon regarding the problem. They authorized a return, so I sent them the water pump. I was surprised to get a credit on my credit card for $278, which was the entire cost of the kit.. That was a big surprise to me, as I fully expected a refund for the water pump only. I can't argue against Amazon's generosity, but it still surprises me. Quote Link to comment Share on other sites More sharing options...
jp98 Posted May 12, 2018 Share Posted May 12, 2018 You were suppose to send them the whole kit, if the water pump came in the kit. Quote Link to comment Share on other sites More sharing options...
moosens Posted May 14, 2018 Share Posted May 14, 2018 Bump for another round of exposure. I’m about to freshen up a 95 2.2 for my 92 daily driver. Just broke the old timing down and looks like all NSK bearings that are still rolling nicely , but will be replaced. It’s a $150 engine from another Subaru head. Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 15, 2018 Share Posted May 15, 2018 (edited) I have lots of used belts and pulleys that are good. $15+ shipping. I've never seen a belt break, even really old dry cracked ones. It's usually the tooth idler that goes. Edited May 15, 2018 by lmdew 1 Quote Link to comment Share on other sites More sharing options...
heartless Posted May 15, 2018 Share Posted May 15, 2018 I have lots of used belts and pulleys that are good. $15+ shipping. I've never seen a belt break, even really old dry cracked ones. It's usually the tooth idler that goes. I have had them break before - thankfully on non-interference engines. Quote Link to comment Share on other sites More sharing options...
Bushwick Posted May 15, 2018 Share Posted May 15, 2018 I have lots of used belts and pulleys that are good. $15+ shipping. I've never seen a belt break, even really old dry cracked ones. It's usually the tooth idler that goes. My mom gave me her '91 Geo Storm GSi many years ago with about 60k miles on it. It had the DOHC 1.6L non interference. It broke the factory belt @60.5k miles, while lightly accelerating before shifting into 4th. Although a completely different Japanese engine (Isuzu IIRC) belts break regardless. 1 Quote Link to comment Share on other sites More sharing options...
moosens Posted May 15, 2018 Share Posted May 15, 2018 Thanks ! Larry , pm’d ya. Quote Link to comment Share on other sites More sharing options...
