Otterby Posted May 27, 2018 Share Posted May 27, 2018 My ‘78 Brat with a 4 speed is difficult if not impossible to get into reverse most of the time. All other gears go in just fine. Is this a clutch adjustment issue or something deeper? Quote Link to comment Share on other sites More sharing options...
charles_thomas Posted May 27, 2018 Share Posted May 27, 2018 Hard to say without more info. Usually, when clutch is going, or cable is bad, the reverse goes first. Is it grinding? Or just slippinh a lot?does it occasionally just pop out? Quote Link to comment Share on other sites More sharing options...
Otterby Posted May 27, 2018 Author Share Posted May 27, 2018 No grinding, slipping or popping out. Just difficult to get it into reverse. Have to really slam the shifter a few times before it engages into the reverse position. Quote Link to comment Share on other sites More sharing options...
moosens Posted May 28, 2018 Share Posted May 28, 2018 Are you confident that otherwise the clutch pedal action is sufficient ? I’d start there having had several with occasional similar issues. If you haven’t experienced pedal box failure you likely soon will. Check the pedal box at the clutch side. You may find a crack which has the thin sheet metal flexing and causing just enough disturbance to just show up with reverse , for now. If that’s the case it’ll get worse. And you can buy cable after cable. Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 28, 2018 Share Posted May 28, 2018 So, is it grinding if you try and shift slowly? If so, it is a clutch disengagement issue. If it is not, then it has likely had the teeth of the reverse gear ground down from abuse, or poor clutch adjustment. This makes it difficult to engage, because the flattened edges of the gears catch on each other. These cars were never super easy going into reverse, and some people get frustrated and abusive with them. Hold pressure on the shifter while slowly letting the clutch out, and it will align the gears and drop in. Quote Link to comment Share on other sites More sharing options...
moosens Posted May 29, 2018 Share Posted May 29, 2018 These cars were never super easy going into reverse, and some people get frustrated and abusive with them. Hold pressure on the shifter while slowly letting the clutch out, and it will align the gears and drop in. - all very true 1 Quote Link to comment Share on other sites More sharing options...
gabianchi1957@gmail.com Posted June 6, 2018 Share Posted June 6, 2018 Check the bolt that links the shifter to the transmission input shaft, I have had the same problem, the bolt was half way worn out, replaced good to go. Quote Link to comment Share on other sites More sharing options...
