wheel bearing / grease fitting ????
3 replies to this topic
#1 Guest_baccaruda_*
  • Guests
Posted 11 August 2003 - 03:52 AM
is there any reason that one couldn't drill into the spindle (front or rear) with the bearings out and install a grease fitting? As long as the fitting isn' t deep enough to hit the bearing, and the hole's smooth, it seems like a great way to refresh the grease once in a while.... ???
#2 Guest_Tolerance02_*
  • Guests
Posted 11 August 2003 - 04:55 AM
I guess it's possible but there is a big chance that grease is going to come out true the seals and inside the brake drums or discs after a while.
#3 Guest_OH Noah_*
Guest_OH Noah_*
  • Guests
Posted 11 August 2003 - 06:03 AM
I'm pretty sure that someone here has done this (Hatchpatrol member?) It works out real well, because there's a spacer between the bearings.
#4 Guest_baccaruda_*
  • Guests
Posted 11 August 2003 - 09:17 AM
Hi noah.. yeah, i was thinking about aiming for the spacer.
Tolerance, I disagree as extra grease is designed to escape thru the split in the spring washer on the end of the axle.. thanks though :)
