cole098 Posted July 11, 2004 Share Posted July 11, 2004 Clock keeps time when car is running but shut off the key and no more correct time.. resets itself back to 1:00.. any ideas how to check or fix??? Thanks Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 11, 2004 Share Posted July 11, 2004 Same problem here - never have figured it out. I swapped the cluster and it didn't help, so it's not in there..... GD Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 11, 2004 Share Posted July 11, 2004 Maybe part of the electrical system that feeds the clock when the car is turned off is broken. I would check a diagram for grounds and especially power and how it gets to the clock when the car is shut off. Quote Link to comment Share on other sites More sharing options...
84Scoobaroo Posted July 11, 2004 Share Posted July 11, 2004 Happened to me too, but it was just a fuse. If not that, i would check the power/grounds, and rewire if necessary. *shrug* Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted July 11, 2004 Share Posted July 11, 2004 In the wiring harness it's either behind the cluster or under the dash somewhere, there is a wire with a fuse in it, may or may not have a quick disconnect on it. This is teh keep-alive wire for the clock. Basically, they shipped them with the wire disconnected so teh batteries wouldn't drain on the boat ride over here, and they were hooked up at ususally at the final delivery point. Yours might have come disconnected, or blew the fuse. Look for a wire with an inline fuse holder in it, I think it's light blue in color. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted July 11, 2004 Share Posted July 11, 2004 unplug your door open chime Shawn had this exact same problem,and that took care of it.... Quote Link to comment Share on other sites More sharing options...
cole098 Posted July 12, 2004 Author Share Posted July 12, 2004 Well I was poking around under the fuse box to reset the EGR Valve ( ON MY BRAT)by doing the wire swap Shawn described when I found a two green wires under the dash that seem to go together.. I connected them and bingo the clock is keeping memory.. But it seems that it might be draining the battery down... Ill leave it hooked up and check it out around 6 PM Monday 7/12. I also found another green wire with nothing connected to it... I looked at this same wire on my other subie and found that wire being used for power to a switch under the dash someone put in that leads to the front of the car under the bumper. The wire gauge is small so I assume it didnt power anything big like fog lights. Anyone use this wire for power for somethin like lights ??? If I can figure out how to put a pic of the Brats wires I will.. Joe unplug your door open chime Shawn had this exact same problem,and that took care of it.... Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 12, 2004 Share Posted July 12, 2004 The two green wires with the mating connectors are there to run the ECU in a service mode I believe. You don't want to leave these wires connected for normal operation. Quote Link to comment Share on other sites More sharing options...
oddcomp Posted July 12, 2004 Share Posted July 12, 2004 uh small wire running to the front.. my guess is that small wire was used to trip a relay to then power up fog lights btw relay powering extra lights of anykind is pretty much the ideal way to do it less wires running backa nd fourth full voltage and amperage instead of losing some of it to a switch and long wire runs less chance of a fire or a short Quote Link to comment Share on other sites More sharing options...
