Stereo wiring 86 GL-10
7 replies to this topic
#1 roger1
roger1
    USMB Regular
  • PipPipPip
  • 81 posts
  • new mexico
Posted 11 July 2004 - 11:20 PM
Some nice thief cut the wiring harness of stereo taking plug of stereo unit and mating connector. I have a another radio with a plug and another female connector to splice on to main harness. In reviewing the colors they don't match to wires on harness. If I have the colors that mate I can have a direction to go. Can someone help me out as I can rearrange them to work ( Ihope !)
#2 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 12 July 2004 - 08:02 AM
Rog:
Sorry about your loss...hope you get a chance to confront the person responsible some day (a thief's worst nightmare!!) .
I usually start by probing the bare wires independently (without the aid of a schematic). You can use a simple "light bulb tester". Just attach one end to the harness wire, and the other to chassis ground, and try various key positions. This will identify your hots pretty quickly.
Then I usually break out the schematic, and verify the hots. For the speaks (if they are still there), you can rig up a homemade tester out of any radio with a speaker or headphone output. Referring to the schematic, you should be able to send a signal to each of your speaks.
By process of elimination, you'll be able to identify ground, and any other leads. You may have a power antenna on that model.
If you run into any probs, or need the schematic,email me.
good luck, John
thealleyboy@yahoo.com
#3 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 12 July 2004 - 09:24 AM
Here is a copy of a post that was from Subarutex about the same thing.
Was just looking through FSM today to find this stuff. Here is the info:
L - Blue
B - Black
Y - Yellow
G - Green
R - Red
W - White
Br - Brown
Lg - Light Green
Gr - Gray
Ignition power source - LY
Ground - B
Positive right front - W
Positve left front - Y
Ground right side - LB
Ground left side - LR
Positive right rear - WL
Positive left rear - YW
#4 hootowl53577
hootowl53577
    New User
  • Pip
  • 5 posts
  • Plain
Posted 04 July 2005 - 08:29 PM
I looked all over the web, bought a $20 Chilton's manual. I still couldn't figure out those speaker wires. Then I found this Message board! My new stereo and speakers sound great!
Thanks guys.
#5 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 04 July 2005 - 08:54 PM
Glad to hear it helped you out. Lots of good help.
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 05 July 2005 - 12:01 AM
the green wire will be hot all the time for memory
the suabr has a common ground speaker, so on the aftermarket radio you will hook up the +left front, the+left rear, and only one of the grounds from the radio will be used, so the left sude front and back share the same ground, the right front and back share the same ground
so you will be using the front left- and the front right-, the other rear - wires will not be used
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 September 2005 - 09:45 PM
L - Blue
B - Black
Y - Yellow
G - Green
R - Red
W - White
Br - Brown
Lg - Light Green
Gr - Gray
Ground - B
Does NOT correspond with 1986 spec GL-10 wiring.
*searches more*
#8 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 20 September 2005 - 10:55 PM
Connector, Stereo side (probably 1986/earl 1987 Spec)
Left Side Ground- Yellow
Right Side Ground- White
RF- Yellow/Red
RR- Grey
LF- Yellow
LR- Yellow/Black
Connector, CAR side (1987 RX)
LS Ground- Blue/Red
RS Ground- Blue/Black
RF- White
RR- White/Blue
LF- Yellow
LR- Yellow/White
There...lol
I just got done wiring in my Pioneer MP3 headunit. Yay!
