mbshop Posted July 12, 2004 Share Posted July 12, 2004 anyone got instructions how to replace the cabin filter on a 2001 outback? thats the optional one for the a/c system. thanks, george Quote Link to comment Share on other sites More sharing options...
Setright Posted July 12, 2004 Share Posted July 12, 2004 Not exactly, but usually if you remove the glovebox, you gain access to the ventilation system. There should only be two screws, securing the bottom hinges. The filter slides in and out of the vent housing. Quote Link to comment Share on other sites More sharing options...
Rich in NEPA Posted July 12, 2004 Share Posted July 12, 2004 Every replacement filter kit I've ever gotten has had the installation instructions included. The only slightly tricky part is removing the glove box because it requires pushing in on the sides to release two pins. Other than that it's a fairly simple and easy procedure. You can check out these instructions: http://www.subaruparts.com/guides/Legacy_Air_Filter.pdf. Cheers ... Quote Link to comment Share on other sites More sharing options...
mbshop Posted July 14, 2004 Author Share Posted July 14, 2004 thanks for the info. i wanted to check them first before paying out the big $$$$$$$. george Quote Link to comment Share on other sites More sharing options...
