1998 subaru outback oil pump leak
1 reply to this topic
#1 camilleh
    New User
  • Pip
  • 1 posts
  • provo
Posted 19 July 2004 - 09:34 AM
I have a oil pump leak on my 1998 subaru 2.5l outback. I have taken it apart three times. The first time I replace the o-ring and gasket. I used a high temp silicon gasket. It still leaked. I'm pretty sure it is leaking around the bottom bolts close to the o ring because there is no oil residue above these bolts. I took it apart again and used an anaerobic gasket and it is still leaking. I think the gasket might be failing inside near the o ring. I'm wondering if there is some other type of gasket material I should use. Or if I should put something on the bolts.
Thanks in advance!!
#2 theotherskip
    Eat, Live, Breath Subaru
  • 329 posts
  • Philly, PA
Posted 19 July 2004 - 05:03 PM
subaru recommends permatex ultra-grey #599:
Posted Image
