subiemech85 Posted July 20, 2004 Share Posted July 20, 2004 do I have to use the ea82 clutch disk? wantintg and needing to use as much ea81 as possible Quote Link to comment Share on other sites More sharing options...
mcbrat Posted July 20, 2004 Share Posted July 20, 2004 yes. the ea82 trans input shaft has a different spline count, so you need to at least use the ea82 clutch disk (225mm) and release bearing. since it's an 84 Brat, it already has the 225mm pressure plate and flywheel, and you can reuse those. I followed the directions here: http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f29b750a92b88.77574552.art when I put the 5 speed in my red brat last month, but I used the 5 speed flywheel and pressure plate. for the do I have to use the ea82 clutch disk?wantintg and needing to use as much ea81 as possible Quote Link to comment Share on other sites More sharing options...
