Blowing white smoke
11 replies to this topic
#1 Alex C
Alex C
    Eat, Live, Breath Subaru
  • 273 posts
  • Ashland
Posted 20 July 2004 - 11:48 PM
I was running around medford this evening and my car started billowing white smoke. It still runs ok and I even got home to ashland, It didnt get hot until I got off the freeway and dropped my friend off.
IM thinking i can fix it this weekend, but, I have no ride till then, which sucks.
I think i blew a headgasket, but Im hoping its somethign easier. and of course I dont know which one.
Alex
#2 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 21 July 2004 - 01:42 AM
Did you check the oil? If it's milky white, it's most likely means the gasket is gone. The radiator fluid might have oil in it? Or if you have access to a compression tester, you could test it.
#3 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 21 July 2004 - 03:26 AM
if neither the oil or the antifreeze has the other in it, yo might have a cracked head which means you can drive around for awhile like that:D I did it in an 86 turbosedan and it lasted a few months before the head cracked wide open and like a river, flooded into the exhaust:-\
#4 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 21 July 2004 - 05:56 AM
check the heater hoses mine did the same thing i had a bad heater core and hose , just something easy to check
#5 Alex C
Alex C
  • 273 posts
  • Ashland
Posted 21 July 2004 - 09:34 AM
This came out of the exaust. I think its a head gasket. I havent checked the oil yet or the water (this evening when I get home via bus).
What head gaskets should I order?
#6 XT Fan
XT Fan
    USMB Regular
  • PipPipPip
  • 76 posts
  • Norfolk
Posted 21 July 2004 - 10:44 AM
My 89 Turbo wagon was doing that. We thought blown head gasket as well. It turned out to be a broken water tube in the turbo unit.
#7 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 21 July 2004 - 06:47 PM
i would use napa complete set around 200 bucks ,it comes with alot of gaskets all possible needed and then some
#8 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 21 July 2004 - 09:35 PM
Intake manifold gaskets will blow lots of perdy white smoke too. Check those b efore you start pulling heads :)
#9 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 22 July 2004 - 12:02 AM
coughcompressioncheckcough
#10 Alex C
Alex C
  • 273 posts
  • Ashland
Posted 22 July 2004 - 12:33 AM
well some moron didnt put the radiator cap back on after filling the water up after noticing the smoke last night in medford. So no wonder it got really hot (about 2mm below the pull over or die line). :rolleyes:
I filled the water up today after work (PS, the bus sucks), Checked the oil. No water in the oil, and no oil in the water. I got in and it started right up, no weird idle or any other signs of a massive failure. Also, it isnt blowing any more smoke( steam?). :banana:
IM going to take it to work with me tomorrow and see what happens.
Alex
#11 Adam N.D.J.
Adam N.D.J.
    Quite Rusty, but working.
  • 3,290 posts
  • Medford, Oregon
Posted 22 July 2004 - 12:48 AM
Just a thought, but isn't your rig an automatic?? If the diaphram broke and it's now sucking huge amounts of ATF into the intake, it will blow billowing white smoke.
So I guess the question is, do you have a bit of steam coming out the rear, or are you pumping out clouds?
#12 Alex C
Alex C
  • 273 posts
  • Ashland
Posted 22 July 2004 - 01:00 AM
yesterday, there were clouds after hitting the gas, but then it was just wisps while driving steady, today nothing.
