YO, I was wondering if a turbo 5speed 4x4 tranny will work on my spfi? I know the axles are different, but I can use those turbo axles on my car, right?
Thanks!!!
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
will turbo 5speed work on spfi?
Started by
ManYaiK
, Jul 28 2004 01:52 AM
4 replies to this topic
#1
Posted 28 July 2004 - 01:52 AM
#2
Posted 28 July 2004 - 02:52 AM
yep! you'll need the vacuum gadgets to activate the 4WD though. above the master cylinder, two black solenoids with gren plastic snouts for the vacuum lines, which should to to a 5" disc thingy on the trans. wire it up and use the shifter from the turbo car, or use another switch. take the shifter linkage too because sometimes those are different. exhaust to trans mount might be off too, no biggie.
#3
Posted 28 July 2004 - 11:28 AM
You'll need to swap the rear differential too. Your car has a 3.9, the turbo trans is geared for a 3.7. Install the trans without swapping the diff, and when you engage 4WD everything will go kablooey. So... you'll need the trans, axles, and diff. If you're converting from an automatic, you'll need quite a bit more...
#4
Posted 28 July 2004 - 02:42 PM
the car will be totally gutless, turbo transmissions are geared for taller shifts, b/c turbo = more power, so later shifts. by all means go with with a 3.90, preferably a dual range 5spd, myself and a few others run 3.90's in turbo cars, closer ratio shifts = more torque to the ground. In my opinion the only reason to run a 3.70 trans is if it had fulltime 4wd and you wanted only to drive/race on the street.
without too much work any trans from a 80-89 roo will fit, but do yourself a favor and stay with 3.90
#5
Posted 28 July 2004 - 03:25 PM
okay, thanks fer da info guys!!!
Dave
Dave
