Disabling air bag
4 replies to this topic
#1 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 28 July 2004 - 09:34 AM
I'm going to be installing a new cruise control switch in my Outback. I'd like to disable the air bag, is it possible to just unhook the negative battery cable and pull the fuse that controls the air bag?
#2 RallyKeith
RallyKeith
    Got Subaru(s)?
  • 1,500 posts
  • Reading, Pa
Posted 28 July 2004 - 10:05 AM
I'm going to be installing a new cruise control switch in my Outback. I'd liek to disable the air bag, is it possible to just unhook the negative battery cable and pull the fuse that controls the air bag?
Yes and yes. I'd advise just simply pulling the negative off the battery while you do the work. That way you cover all possible bases to be safe. At that point pulling the fuse is no extra help, so just the battery will be fine.
Keith
#3 gbhrps
gbhrps
    20 Year Subie Fan
  • 1,103 posts
  • Canada
Posted 28 July 2004 - 08:25 PM
BE CAREFUL!!!!! The airbag assembly has an onboard capacitor that retains an electrical charge for as long as a half an hour after the battery has been disconnected. It could still fire off in that time if you are not careful. Pull the battery cable and wait 30 minutes to be safe, before you mess with the steering wheel. The backup system is designed into the airbags in the event that some severe collision should quickly cut the battery out of equation. In the case there would still be enough juice to fire off the bags and prevent injury to the occupants. Please don't quote me, but I believe this is what I have read somewhere in the last two or three years, I just can't recall where. Anyone else out there who can verify or update my information?
#4 SevenSisters
SevenSisters
    Subaru Nut
  • 512 posts
  • Cleve/Akron Ohio
Posted 28 July 2004 - 08:51 PM
I think you're right. That's why a lot of rescue workers get hurt trying to extricate crash victims. No way to shut them down fast.
#5 avk
avk
    Certified Subaru Nut
  • 965 posts
  • Somerset County, NJ
Posted 28 July 2004 - 09:23 PM
The back-up is in the control module. Can't argue against waiting, but all one needs to do is to unplug the airbag and put away.
