88xt6joe Posted July 31, 2004 Share Posted July 31, 2004 Blower motor was working but now it is not. I assumed it was the fuse in the fuse box but I looked at it and it was good. Are there other fuses or relays to look for? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
sea#3 Posted July 31, 2004 Share Posted July 31, 2004 88xt6joe Does it work on any of the speeds ? If it works on 4 and not on 1-3 it is probably the drop resistor is open , It"s located behind the glove box in the heater housing ( Look for a white connector with 4 wires ) SEA#3 Quote Link to comment Share on other sites More sharing options...
88xt6joe Posted July 31, 2004 Author Share Posted July 31, 2004 No it is not working at all!! Joe 88xt6joeDoes it work on any of the speeds ? If it works on 4 and not on 1-3 it is probably the drop resistor is open , It"s located behind the glove box in the heater housing ( Look for a white connector with 4 wires ) SEA#3 Quote Link to comment Share on other sites More sharing options...
SevenSisters Posted July 31, 2004 Share Posted July 31, 2004 I believe there is a blower motor relay you should check first. If that's not the culprit, you'll have to start checking for power at the blower motor and back through the system. Could be the blower motor brushes. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted July 31, 2004 Share Posted July 31, 2004 88xt6joe SevenSisters is right. Start by checking for power right at the motor first ( if memory serves me right there should be a red wire and a black wire running into the motor ) If there is power and the ground is ok , give the motor a "TAP" and see if it comes back to life ,if it does then you’ll be buying a motor The relay should be by the A pillar and the glove box opening (Can’t remember the color of the relay, but look for the color of the power wire for the blower motor) SEA#3 Quote Link to comment Share on other sites More sharing options...
88xt6joe Posted July 31, 2004 Author Share Posted July 31, 2004 I'm gonna have to wait until Monday to test it because all my test stuff is a work I'll keep you posted. Joe Quote Link to comment Share on other sites More sharing options...
