HELP! Clutch just went to floorboard
10 replies to this topic
#1 tracedog67
tracedog67
    USMB Regular
  • PipPipPip
  • 69 posts
  • Cincy, OH
Posted 03 August 2004 - 05:03 PM
Fellers,
1997 OBW, 5 MT, 227k miles, I pulled into the entrance of our subdivision (thank goodness) and my clutch stayed on the floor, it wouldn't come back up. I know I have lots of miles on this car but the first owner drove 70 miles one way to work everyday so the miles are mostly highway. I had a clutch go out before on a Tbird turbocoupe so I know the signs of a clutch going out. The OBW shows no signs of the clutch giving out, is there a return spring of some kind that may have broke? Please help i'll be stranded at home tomorrow if I don't figure this out. After just shelling out $400 for exhaust work on our SVX I don't want to have to put more into another car after I got the OBW running great with new headgaskets and such.
thanks for this board.
Tdog67
#2 RallyKeith
RallyKeith
    Got Subaru(s)?
  • 1,500 posts
  • Reading, Pa
Posted 03 August 2004 - 05:25 PM
Fellers,
Tdog67
I know this might sound stupid, but did you try pulling it back out? I know that at some point Subaru went to Hydraulic clutches. If your car has a hydraulic clutch then there is the possibility of the pedal traveling far enough that a spring somewhere doesn't do it's job and the pedal stays. All I've ever done when that happened was reach down and pull the pedal back.
Keith
#3 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 03 August 2004 - 05:28 PM
Fellers,
Tdog67
Clutch Master Cylinder
This is not that big of a fix, you can rebuild it yourself or get a rebuilt one.
#4 hohieu
hohieu
    Subaru Nut
  • 569 posts
  • Philadelphia
Posted 03 August 2004 - 05:33 PM
Do title search for "clutch pedal" and you'll see some threads on clutch pedal sticking (down to the floor). It's probably a hydraulic issue, not a mechanical one.
#5 canajun2eh
canajun2eh
    USMB is life!
  • 222 posts
  • Ottawa, ON, Canada
Posted 03 August 2004 - 05:51 PM
When that happened on my 92 Legacy, it was a broken clutch cable. I don't know whether your car has a hydraulic clutch or a mechanical one.
#6 nickb21
nickb21
    Subaru Fanatic!
  • 567 posts
  • Hunterdon County
Posted 03 August 2004 - 06:03 PM
This might help, if copy and paste works..
http://pub205.ezboar...icID=7875.topic
#7 sprintman
sprintman
    USMB Regular
  • PipPipPip
  • 105 posts
  • Canberra Australia
Posted 03 August 2004 - 06:06 PM
I had same problem. Free slave cylinder etc under the TSB. They gave me a new clutch free earlier as well. Good luck!
#8 tracedog67
tracedog67
    USMB Regular
  • PipPipPip
  • 69 posts
  • Cincy, OH
Posted 03 August 2004 - 06:11 PM
The master cylinder was a little low of DOT 3 so I filled it up but the slave cylinder ( I assume this is the very small 3/4" cylinder with a small rod coming out of it) doesn't seem to want to go back each time. Yes, I can pull the clutch up with my foot but if I turn the ignition on it does it again. BTW, my wife drove the car yesterday and she hasn't drove a stick for years ( I hope she doesn't read this or Mr. Happy will be on bread and water for a month).
Keep the suggestions coming please, where do i get these parts quickly.
thanks
Tdog
#9 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 03 August 2004 - 07:29 PM
I hate to say this, but it sounds like the pressure plate kicked the bucket. Regardless of how it was used, 227,000 miles is a lot for a clutch. Be happy it went that far. My Legacy clutch went from driveable to undriveable in 6 miles, the release point being on the floor. When I pulled it into the mechanic the next day, the pedal stayed on the floor.
I'm not ruling out a hydraulic issue, it's entirely possible. But it does sound to me like new clutch time.
#10 tracedog67
tracedog67
    USMB Regular
  • PipPipPip
  • 69 posts
  • Cincy, OH
Posted 03 August 2004 - 07:38 PM
When I opened the hood i noticed that there appeared to be some wetness near the firewall. With the hood up I pumped the clutch and noticed something spraying on the windshield. My wife pumped the clutch and I was relieved to see that the hydraulic hose has a leak in it near the end of the coupling, so I hopefully just need a new hose. Is there an easy way to get this part, do you think some kind of tape would hold it until a new hose can be found?
thanks for the quick responses
Tdog
#11 sprintman
sprintman
    USMB Regular
  • PipPipPip
  • 105 posts
Posted 04 August 2004 - 05:53 PM
The TSB applied to slave cylinder and hose etc. Not sure if that covers 97 model though.
