88 subaru GL auto transmission cooler lines location
changed water pump the other day and went to put the radiator back. For
an automatic tranny equiped cars, the tranny fluid is cooled by running
the tranny lines into the radiator. I got the lines mixed up and do not
know where they are supposed to go back in. From the tranny, there is
one line coming from the front left side and another coming from the
rear left side of the tranny. Both these lines are run into to the
left side of the radiator, one at the bottom and the other at the top.
I need to know which line goes into which part of the radiator.
I got 88 GL 1.8L FI EA82 non-turbo 4-door with an automatic. The Haynes
manuel I have does not seem to have a diagram showing the tranny cooler
lines going into the radiator. I forgot to lable them when I took them
out, creating the problem I have right now.
any help is appreciated
Also it is a 2WD not 4WD, I am thinking the line from the diff would be flowing to the top of the radiator and the line coming from the bottom of the radiator
would be flowing to the pan on the transmission.
Any help appreciated
thanx
