Hello, I am not sure of which one would be best, the kit mentioned in "DUAL PORT HEADS!!! (EA-81)" or "Anyone interested in EA-81 HI-PO rebuild kit?"
the dual port heads and custom intake manifold rock, but the cam you need would suck as it would probabaly be around 4,000 - 5,000 rpm.
but what if you got the custom manifold (the one made for the webber) with huge-ported normal heads and use EA71 pistons to increase the CR and use the stock cam?
am I making sense?, or would that not work?
thank you.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
dual-port kit or the other one?
Started by
Guest_jcdenton_*
, Aug 10 2003 12:12 AM
4 replies to this topic
#1
Guest_jcdenton_*
Posted 10 August 2003 - 12:12 AM
#2
Guest_GeneralDisorder_*
Posted 10 August 2003 - 12:39 AM
I doubt the stock cam is designed to flow enough for the amount of breathability you would gain from the heads, and intake. Just wouldn't match.
#3
Guest_jcdenton_*
Posted 10 August 2003 - 12:50 AM
so the only performance cams we can get wouldn't work well for our engines.
#4
Guest_Tom63050_*
Posted 10 August 2003 - 10:51 AM
According to Emily, the Brat cam is torquey, the 2WD cam is for HP, and the non-Brat 4WD cam is an average of the two. If we want more flow maybe the way to go is 2WD cam. Or get one of those cams the aircraft guys sell.
#5
Guest_SubaruJunkie_*
Posted 10 August 2003 - 10:57 AM
If your going to go with a dual port head, your going to want a cam that will be able to use all that air and fuel comming in. Unfortunatly, i dont think we're going to get good torque or hp at low rev's with a dual port head. For power in the low revs, you might consider just a plain jane EA81 with a weber.. maybe a mild cam and some small tweaks like timing etc. For big power in the high rev's, then the dual port head will work good. With our OHV engines, with a nice set of rockers and a well ballanced engine, i dont see why we cant hold a steady 5000+ rpm for the street
-Brian
-Brian
