have you checked the codes? But yeah...sort of sounds like a coolant temp sensor.
Yes I agree with Josh
Depending on how the coolant temerature sensor fails . If after checking the codes you disconnect the battery for say 30 minutes this should reset the alarms. The fans may then not turn on at start depending on how the alarm is processed.
My guess is that you have had the check engine light up sveral times and not taken any action so after say 5 or 10 such events the ECU has latched the fans up
ok im gonna go with the coolant sensor, now one question? where is it? i see a sensor under alternator but it only has 1 lead, i asume thats for the gauge and not the computer sensor? this is on a ej22 engine
Thnx Again, Mark
