Svx Vlsd?
12 replies to this topic
#1 CIS Subaru
CIS Subaru
    User Awaiting Email Confirmation
  • 1,992 posts
  • Columbus, OH
Posted 09 August 2004 - 10:15 PM
I'll ask you guys first, and if nobody knows, then I'll try the New Gen forum.
I just bought an SVX rear diff with only 95k miles on it (for a whole $20), and I'm trying to figure out if it is possible to swap the VLSD parts into a regular 3.9 rear diff like you can with the clutch-pack type LSD. Does anyone happen to know??
For those who are wondering, the SVX rear diff seems to be a 3.545 ratio R160 diff, but like a later Legacy diff, it doesn't have stub-axles like our R160s do. So since it has a totally useless ratio for me, and my axles won't connect to it, I figure the only way it'll be any good to me is if I can gut it and put the VLSD parts into one of my open 3.9 diffs. Again, does anyone know if this has been or can be done?
#2 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 09 August 2004 - 10:26 PM
It may be possible but you may have top use stub axles from an early legacy or possibly a turbo legacy.
#3 VaporTrail
VaporTrail
    Brattitude Adjustment
  • Administrator
  • 11,115 posts
  • Central Iowa
Posted 10 August 2004 - 07:58 AM
you can buy new stub axles for the early Turbo Legacy VLSD (go in with a C-Clip), but when you see the dealer, with the seals and packing parts, it will be around $350.00 or subaruparts.com had 'em for about $250
But I cannot say for sure if they will work.
the internal VLSD parts is what needs the stub axles.... might be interesting to see if the internals could be modified carefully to allow a bolt in stub.....
#4 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 10 August 2004 - 01:27 PM
I have turbo Legacy 3.90 VLSD in my sedan, it has the stud axle with c-clips, those are what you need. If you run across any more of those, let me know, for $20 plus shipping these would be a great deal.
#5 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 10 August 2004 - 01:34 PM
Is there any particular model that always came with the VLSD in these early Legacy / SVX / Impreza platforms?
I see a lot of Legacys come through local yards now. So far no rear VLSD but I havent been checking them ALL either.
Sorry if this hijacks the thread but it's kinda relavent. What is the difference in those first gens that had "4WD" badges and the ones that had "AWD" badges? Aren't they all AWD ?
Thx !_!
#6 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 10 August 2004 - 05:05 PM
MorganM, besides the Turbo Legacy (91 only) and the SVX, name one other Subaru that came with a VLSD in the USA. All the Imprezas have LSDs, not VLSDs. Imprezas and other EJ series cars do have viscous couplers in the center diff, but not the rear or front diff. Please let me know so that I can start looking for them.
#7 CIS Subaru
CIS Subaru
  • 1,992 posts
  • Columbus, OH
Posted 10 August 2004 - 09:44 PM
So, if I'm understanding correctly, the VLSD parts WILL fit in a standard R160 case?? I'd just need to find stub axles for it or make the bolt-in ones work? Got any part #s for those stub axles?
#8 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 11 August 2004 - 06:47 AM
I might have the part numbers at home, I'll have to get back with you. If you contact a dealer, just ask for the stub axles for the rear diff of a 91 Legacy Turbo.
#9 torxxx
torxxx
    I void warranties
  • Gold Subscribers
  • 2,914 posts
  • Fairbanks
Posted 05 February 2009 - 08:21 PM
VLSD will fit but you have to do some grinding on the sides of the case to make it fit. The stub axles will not work as far as I know there isnt threads for the bolts. I'm running the c-clip stubs on mine with 5 inches of lift in the rear (angle wont snap axles but it pulls kinda hard on them) and I've never had a problem with them popping out.
#10 Gloyale
Gloyale
    It's a sickness
  • 7,099 posts
  • Corvallis, OR PNW
Posted 05 February 2009 - 08:26 PM
I believ you will need a set of SVX axles. Fit the SVX inner cup, cage onto the GL/XT shaft and race.
I was looking into this recently and had this method confirmed by folks who've done it.
search and I had a recent thread about this
#11 Gloyale
Gloyale
    It's a sickness
  • 7,099 posts
  • Corvallis, OR PNW
Posted 05 February 2009 - 08:27 PM
SVX diffs are different, different, different.
It will work, buit you need the inner joints of the SVX axles, which insert into the diff.
#12 Durania
Durania
  • 3,113 posts
  • Crossville, TN
Posted 05 February 2009 - 08:56 PM
Almost 5 years I hope it was resolved.
#13 edrach
edrach
    Charter member OFRT
  • 12,304 posts
  • Bothell, WA
Posted 05 February 2009 - 09:48 PM
That same 4.454 VLSD come in two years of the WRX also; I believe it was 2001 and 2002. I've got one of those also; they are only a bolt in on the SVX and certain WRX's.
