Clutch and rear AWD question
2 replies to this topic
#1 mr.radon
mr.radon
    USMB is life!
  • 232 posts
  • Seattle, WA
Posted 10 August 2004 - 09:50 AM
Clutch. I bought a parts car for the 5 speed AWD tranny. I'm converting a FWD auto to AWD manual. The donor car had no history but reading through papers I found in it, the lady who owned it mentioned "Needs new clutch". However, after I pulled the tranny off the car I found that the clutch plat had 50% of the pad left. The pressure plate and flywheel has small blue spots. I've heard this may indicate that the clutch was slipping?!?
I'm replacing the clutch/PP/Rel Bearing/Pilot Bearing. Anything to be concerned about?
Rear AWD (1988). Bought rebuilt rear half shafts. They came without the dust boot (end caps) on the half shafts. Are these important?
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 10 August 2004 - 11:00 AM
Check for cracks in the flywheel. and have it resurfaced. You should be good to go.
#3 VaporTrail
VaporTrail
    Brattitude Adjustment
  • Administrator
  • 11,114 posts
  • Central Iowa
Posted 10 August 2004 - 11:19 AM
you can tap off the dust caps off the old axles on the donor (if it has them) and put them on the new axles. not necessary, but good to have to help protect the seals from road hazards, gravel, etc.....
