EA81 Cruise Control problem
7 replies to this topic
#1 Mac
Mac
    Eat, Live, Breath Subaru
  • 277 posts
  • Baton Rouge, LA USA
Posted 14 August 2004 - 02:08 AM
CC is on an '84 GL SW, carbed 4-speed, D/R.
Not sure this is vacuum related, electrical or both. Here's the deal: Go to set cruise and more often that not it engages for a couple seconds then drops off. If I try to set it again, nada. If I leave the CC switch on, it may kick back on for a few seconds at some point or another down the road as if infested by ghosts. Sometimes it engages but won't set at the speed. Just keeps on going, pedal to the metal, until I turn the switch off about 6 inches from some guy's rear bumper. Resume and coast don't work at all in any situation.
Not even sure where the computer is located.
Any assistance rendered would be appreciated!
#2 Mac
Mac
  • 277 posts
Posted 14 August 2004 - 10:34 PM
Bump
#3 RenaissanceMan
RenaissanceMan
    Why am I here?
  • 706 posts
  • Eugene, OR
Posted 15 August 2004 - 01:17 AM
go down to the hardware store, and get a throttle control lever and cable, for a lawn mower. Mount the sucker on the console and attach the cable to the carburetor. boom, instant cruse control garunteed not to fail. :drunk:
#4 Mac
Mac
  • 277 posts
Posted 16 August 2004 - 11:09 AM
Thanks for the reply. I've got to remember that trick. But now, since I have the cruise, I wouldn't mind figuring out how to fix it.
#5 RenaissanceMan
RenaissanceMan
    Why am I here?
  • 706 posts
  • Eugene, OR
Posted 17 August 2004 - 10:27 AM
Haha, this time I wont be a smart@$$. so anyway. It sounds like the speed sensor in the spedometer is fubar. at least I think on those carb models it was in the spedo... Time to check the FSM on where that little buggar is.
Hope that can point you in the right direction..
-Mike
#6 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,588 posts
  • Hillsdale, Mi. USA
Posted 18 August 2004 - 02:12 AM
In my experience of working on "other makes" of vehicles, a vacuum leak would be the 1st thing to rule out. Any leak would basically keep it from working, and for sure wouldn't cause it to be so erratic.
Best guess would be something amiss in the control switch and/or it's wiring, as in a shorting of juice across the circuits there in. Would look there first, then start checking the rest of the system out. The speed sensor could be culprit, but they usually just plain die.
No clue as to locale of control unit really, but thinking it's under the dash to the right of the steering column, above where the ECU is/would be. Think I read that somewhere.
#7 Mac
Mac
  • 277 posts
Posted 19 August 2004 - 02:24 AM
I have the FSM but no mention of the cruise control in it.
I'll check there. Also, I'm pretty sure the "soup can" with the other thing attached to it, attached in the engine compartment to the firewall on the passenger side, has something to do with the cruise control.
#8 Mac
Mac
  • 277 posts
Posted 08 October 2004 - 11:32 PM
HELP!!!!
My local junkyard just towed in an '84 GL Wagon. It has cruise control and if I can find the magic box, I can swap it and perhaps solve my problem.
Where is the CC brain on this vehicle?
Only difference between it and mine is my CC button is green and to the lower right of the steering wheel. The CC button on the jy GL is on the column.
Thanks!
