mons72 Posted August 14, 2004 Share Posted August 14, 2004 does any one now from witch car i have take parts from, to do a 5 lugs conversion on my 86 sube. and is it much work with it? im happy with all answeres i get from you all. Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted August 14, 2004 Share Posted August 14, 2004 Well I don't know of any car the stirs a caldron, but if you want to know which car(s) to get the pieces from, I'll tell you. For the rear pieces, you have only one choice, and that is a XT6 AWD, from that you need the backing plate, the hub (the piece that bolts to the axle) and the rotor, the rear caliper is the same as any rear disc EA82. Up front you have some choices for some of the parts, but some must come from a XT6 (either FWD or AWD), you need the lower suspension arm and the ball joint, you'll need the tie rod ends, and you'll need the front calipers. You can get the following parts from a XT6, a Legacy, or an Impreza, the front strut complete, the front rotors, the front backing plates, the front knuckle, and the axles. The Legacy axles may be too long, so I would stay with either the XT6 or the Impreza. Here is a link to my web sitye that shows my first conversion, it should help a little, http://corkysrocks.net/Conversion%204%20to%205.htm . Quote Link to comment Share on other sites More sharing options...
mons72 Posted August 14, 2004 Author Share Posted August 14, 2004 thanks. thats nice:) Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted August 14, 2004 Share Posted August 14, 2004 however the axles wont work with your tranny. i had a D/R tranny and got custom xt6 axles with 23 spline inner joints. as i don't need them they're up for sale... Quote Link to comment Share on other sites More sharing options...
mons72 Posted August 14, 2004 Author Share Posted August 14, 2004 ok, but it's gonna cost a lot to ship it to norway. so i have to try and get the parts from j/y up here. but thanks anyway. Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted August 14, 2004 Share Posted August 14, 2004 oopps!! thought you were in the states! Quote Link to comment Share on other sites More sharing options...
mons72 Posted August 14, 2004 Author Share Posted August 14, 2004 thats ok. no harm done:) Quote Link to comment Share on other sites More sharing options...
$J-MoNeY-$ Posted August 14, 2004 Share Posted August 14, 2004 How much to have the Axels shipped to area code 80904? Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted August 15, 2004 Share Posted August 15, 2004 Yea, I forgot about the tranny, if you can find a tranny out of a EA82 (Leone/Loyal) series turbo, that will work. Quote Link to comment Share on other sites More sharing options...
THAWA Posted August 15, 2004 Share Posted August 15, 2004 The Legacy axles may be too long, so I would stay with either the XT6 or the Impreza. Here is a link to my web sitye that shows my first conversion, it should help a little, http://corkysrocks.net/Conversion%204%20to%205.htm . All the front half shafts are the same length on ej cars. Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted August 15, 2004 Share Posted August 15, 2004 Thanks THAWA, I wasn't sure, I knew the Impreza ones would work, we test fitted them on a RX. They are in fact 4mm longer then the EA82 axles, but I don't think that is enough to make any difference. Quote Link to comment Share on other sites More sharing options...
THAWA Posted August 15, 2004 Share Posted August 15, 2004 so the splines match up and everything? Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted August 15, 2004 Share Posted August 15, 2004 Yep, the splines match a turbo (25 spline) tranny. Quote Link to comment Share on other sites More sharing options...
THAWA Posted September 2, 2004 Share Posted September 2, 2004 sorry, im interested in this again. Is the reason you need xt6 calipers because of the parking brake being on the front brakes in the stock setup? Quote Link to comment Share on other sites More sharing options...
