D/R swap
1 reply to this topic
#1 mdjdc
mdjdc
    1000+ Super USER!
  • 1,329 posts
  • Richmond
Posted 16 August 2004 - 10:14 AM
Hey guys: I have an 87 gl turbo that I have aquired a D/R tranny for. I have the Tranny, Shifters, console, driveshaft, half shafts and the 3.9 rear. Is there anything else I will need before I tear into this job? I looked at the wiring harness and the only difference I can see is the plug for the electric four wheel drive that is on my present tranny. Both ftranies are five speed and the clutches appear to be identical, so that shouldn't be an issue. Just looking for any advice and info before I get the car all torn down.
Thanks
Mike
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 August 2004 - 01:41 PM
the reverse plug should be the same, it should have green and black wiring, i did one on a 5spd 2wd to 5spd 4wd conversion, and the reverse plug fit the same. the trouble was trying to find out which one was the reverse plug.
some instances the wires may be the same but the plug itself may be different
