Brumby cracked torsion bar crossmember
No replies to this topic
#1 Hampton Brumby
Hampton Brumby
    New User
  • Pip
  • 2 posts
  • Lithgow
Posted 17 August 2004 - 09:42 PM
I'd like to know if anyone else has had the problem of the torsion bar crossmember cracking where the rear ground clearance adjustment bolt is located.
I was getting a lot of noise from the rear of my '89 Brumby but the handling was still great. I finally tracked it down to the adjustment bolt. The adjustment bolt had punched through the metal so I can now see the bottom of the bolt. It looks like the metal was double plated under the bolt but metal fatigue has given way. Is this a common problem with age?
I have done 240,00kms (150.000 miles), shifted house a couple of times, occasionally use a trailer and mainly use it on country roads but not much dirt and rarely 4WD off road.
I intend to get a second-hand crossmember and weld a plate on the outside under the bolt to strengthen it and then swap it over.
It was only after seeing the damage that I realised the rear ride height had been slowly dropping. Maybe that is why it handles so good.
