mattyg41383 Posted August 24, 2004 Share Posted August 24, 2004 I have an '85 XT with a EA82t... wondering if there are any bigger throttle bodies that will fit. I eyeballed one off of an XT6 but the mounting holes are different. Also, has anyone put different (upgraded) injectors on the 1.8t? Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted August 24, 2004 Share Posted August 24, 2004 I think that an XT6 TB will work, might only work on a spider manifold, but I know that people swap them on. Quote Link to comment Share on other sites More sharing options...
boing Posted August 25, 2004 Share Posted August 25, 2004 the throttlebody that you are using now should have ample fuel. In fact it has a feature that brings an over amount of fuel to the throttlebody and routes the excess back to your fuel tank. You need to change more than just the TB to make a bigger one work. boing Quote Link to comment Share on other sites More sharing options...
mattyg41383 Posted September 24, 2004 Author Share Posted September 24, 2004 I got thinking about this again. The XT i have is drag-only and I'm running 15psi into that. It pulls real hard but the top end seems to fall off, I'm pretty sure its in need of fuel and i obviously dont want to to lean out too badly. So Im thinking fuel pump, injectors, junk like that. Probably gonna get some Cams done up and a torque converter too. so the question still is, are there better injectors off of another application that will work on the XT? I remember that someone had put an aftermarket Torque converter on a car, any idea where it came from? I was going to send it out to East Coast Converters and have them do it on my old one. -matt Quote Link to comment Share on other sites More sharing options...
oddcomp Posted September 24, 2004 Share Posted September 24, 2004 boing i think you are confusing throttle body injection with a air only throttle body he would be running the air only throttle body.. thats all it does is let in air but i could be wrong he may have a throttle body injection setup and that does air and fuel Quote Link to comment Share on other sites More sharing options...
rallyruss Posted September 24, 2004 Share Posted September 24, 2004 I got thinking about this again. The XT i have is drag-only and I'm running 15psi into that. It pulls real hard but the top end seems to fall off, I'm pretty sure its in need of fuel and i obviously dont want to to lean out too badly. So Im thinking fuel pump, injectors, junk like that. Probably gonna get some Cams done up and a torque converter too. so the question still is, are there better injectors off of another application that will work on the XT? -matt ok if I rember correctly some one in the past stated that the EA82T injectors flowed as much as the stock wrx ones. now I would verify that you are leaning out before swaping injectors. The ECM would not be able to adapt to the larger injectors and you would probably not be able to idle without aditional sofware to control them. personally I feel that you can gain alot more by concentrating on a turbo upgrade and intercooling along with exhaust flow. the stock turbo is great off the line but its too small to give you good top end power. I am in the process of doing a TD04 swap as soon as I get the rest of the needed parts to complete it. I will see if it runs lean at all after the swap but I seriously doubt it as long as I keep boost pressures reasonable. Quote Link to comment Share on other sites More sharing options...
