I have a 1997 OBW and mashed my front catalytic converter and will need to replace it. I'm looking at the Stromung High-Flow cat pipe, which replaces the two stock units with a single. My question is are there any real issues with putting headers on an otherwise stock DOHC 2.5? I figure while I'm under there I might as well do all the work at the same time. Thanks for any info.
The only possible issue that would happen is a possible check engine light, due to a different reading on the rear O2 sensor. You can get a kit that will eliminate that problem for $20, or just have the check engine light on all the time. I have Borla headers on my legacy, and I like them. You can go with the TWE headers if you want to spend a little more money.
--Todd
