Ground Wire Gauge Recommendation, 87 Brat
2 replies to this topic
#1 aba4430
aba4430
    Eat, Live, Breath Subaru
  • 308 posts
  • Pace, FL
Posted 26 August 2004 - 05:13 AM
Folks,
I am going to be redoing the grounds on my Brat soon and was thinking about 8 and/or 10 gauge cable. Streetwires OFC power cables (both gauges) are quite cheap at EBay. Will also make custom battery cables from 1/0 Gauge Streetwires OFC power cable. I appreciate any recommendations.
Regards,
aba4430
#2 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 26 August 2004 - 08:33 AM
I should think the bigger the better for ground wires.
Lots of gremlins have been traced to bad connections at the ground.
#3 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 26 August 2004 - 02:39 PM
For the most part, a Subaru doesn't run enough current to warrant wires of that size. Really all you need are clean connections. Having said that, I'm running 4-ga between the battery and the engine block, the block and the body and the battery to the body. I've got 4-ga running from the battery to the starter and 8-ga to the fusible link cluster. My wire size choices were made predominantly by the fact that 4- and 8-ga wire was what I had on hand when I needed to do all that re-wiring.
Realistically, you could get away with 12-ga grounds all the way around without a problem. You just have to make sure that the connections are clean and tight.
