Help With Auto Trans Problem
5 replies to this topic
#1 mrtoyou7747
mrtoyou7747
    USMB Regular
  • PipPipPip
  • 84 posts
  • Boynton Beach, Fl
Posted 31 August 2004 - 06:28 PM
My 98 OB 122k w/2.5 and 4EAT xmission has started to develop an intermitant problem - while acclerating from stopped or slow speed to say 25 40 MPH. It seems to delay a shift from 2nd to 3rd. It's not slip since the spedo and tach are both moving and it happens rarely although I think it is occuring more often. I can control it a bit with the throtle pedal.
I took the car to a trans shop where they ran the codes and found nothing. They also though it could be the TPS but that seems to be ok.
I checked the fluid - its level, color and smell are OK (I change it every 25K or so)
I looked in my Haynes and it says that the bands may need to be tightened. Yet the trans shop said they don't do that anymore since the trannys are electronically controlled.
They suggested that they test drive it with the OBD hooked up and monitor the shift command to see if its a TCU problem. Failling all else they suggested a teardown and inspection for 500 bucks.
Any ideas?
#2 cadetman
cadetman
    New User
  • PipPip
  • 24 posts
  • North Dakota
Posted 31 August 2004 - 06:41 PM
As a former Service manager for Toyota/Subaru I suggest taking it to a good Subaru dealer for their diagnosis. Trany shops are like roofers......... some good ones out there, but a load of incompedents.
A dealer may charge a fee for the diagnosis but it is worth it and cheaper in the long run.
Later
#3 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 31 August 2004 - 11:07 PM
Cadetman, that is very good advice I wish I would have had it last month. We took our Saturn to a transmission shop for rough shifting they took it apart and rebuild it for 1800.00. The problem was still their when they finished so we took it to Saturn dealer and they found it was the valve body. The cost to fix it was around 500.00 dollars. So we wasted 1300.00. ( we took it back to transmission shop and made them fix it. they said they replaced the valve body but it must have been bad according to them.)
#4 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 31 August 2004 - 11:28 PM
My 90 Legacy does the same thing. IF you find out what it is please shoot me an e-mail or just post it up on here.
Thanks
#5 johnnysubaru
johnnysubaru
    New User
  • PipPip
  • 12 posts
  • Reading, PA, USA
Posted 28 September 2006 - 07:20 AM
Any ideas?
When was the last time you had the transmission flushed?
#6 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,257 posts
  • East Coast
Posted 28 September 2006 - 11:53 AM
all your tires are matching?
