Auto Dim Rear View Mirror
3 replies to this topic
#1 cannonball
cannonball
    User Awaiting Email Confirmation
  • 205 posts
  • Greenville
Posted 13 September 2004 - 02:37 PM
How does one go about cleaning the sensor. It seems to me that it doesn't work as good as the manual flip type. Is the green light the actual sensor as well? I don't want to damge it by any means. Would alcohol and a q-tip be safe?
Thanx,
Charles
I need to add that it's a MY2000 OBW Limited FWIW.
#2 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 13 September 2004 - 06:01 PM
Is your back window tinted? If it is, the auto dim won't work. As fro the sensor, I'm not sure, look on the mirror there should be a small hole in the plastic somewhere on the front side (the part you look at) that is the sensor, there might be some junk in there.
#3 cannonball
cannonball
  • 205 posts
  • Greenville
Posted 14 September 2004 - 07:51 AM
Thanx for the response. I like you user name. My sentiments exactly.
Charles
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 14 September 2004 - 10:26 AM
The sensor could be behind the plastic, plenty of light passes through plastic, so it doesn't have to have a "window" to see through.
Alcohol should be okay, it'll remove grease but won't dissolve the plastic.
