Alex12 Posted September 15, 2004 Share Posted September 15, 2004 I need help with the steering knuckle bearing replacement. I have a 1990 Subaru Loyal. I started with the driveaxle and CV joint repair and I end up replacing lots of other stuff. How much hydraulic pressure do you need to remove the bearings? In which direction do you press the bearing out? What are the steps to take the bearings out? Can I do this with a hydraulic jack? What would be the cost of taking the assembly to an automotive machine shop for bearing change out? Thanks… Quote Link to comment Share on other sites More sharing options...
