My outback has the cold weather package, the passenger seat does not seem to be heating properly. It looks like there are three wires under the seat that plug into the console area into the switch.
Anyone have a service manual that can tell me what wires do what?
It seams like the back heats up a bit but the bottom of the seat gets nothing.
Thanks
There should be 4 wires to your seat heater, unplug at the seat, look at the plug that is attached to the seat, hold the lock tab up, there should be 4 pins, the top row is numbered from right to left, 1, 2. Bottom row is numbered right to left, 3, 4.
Check for continuity between 1 & 3, 1 & 4, and 3 & 4. if one of those has no continuity, you have a open heater loop. You can replace the loops, somewhat difficult though.
Thanks!! I will check these out this weekend!
A question about operation of the Seats.
I get heat on both seats now, but is only the back section on the seat, not the seat bottom (place you put your rear).
Is this correct? Is only the back (upright) portion of the seat supposed to get heat and not the bottom?
Thanks
