Idle problems continue, help! EA81
10 replies to this topic
#1 subiewonkenobi
subiewonkenobi
    New User
  • PipPip
  • 17 posts
  • Nevada City
Posted 16 September 2004 - 02:50 PM
Well, it seems that Murphy's Law is in full effect. The day that I am going to take my 84 GL into get it smogged, the idle starts doing crazy things. It all began after I was "fiddling" around with the intrument panel to get a smog light (ECS) to no longer light up. After that the car would idle around 500-600 rpm, running real rough. Checked all the vac's and no leaks, moved the idle up on the carb and it worked for awhile, but then dropped back down again. And it is intermittent. Sometimes it idles fine and runs great, about 30% of the time, but the rest! It idles real low, and sounds like its misfiring up to about 1500 rpm before smoothing out and running normal. It will change from running bad to running perfect one minute to the next. I didn't disconnect any wiring while in the instrument panel, not sure how that could have caused the problem. A friend mentioned a pcv valve problem he had with his brat that was similar. Any suggestions? I am baffled.
#2 subieman
subieman
    1000+ Super USER!
  • 1,422 posts
  • Sparks, NV
Posted 16 September 2004 - 09:13 PM
Bump!
#3 rubuild
rubuild
    New User
  • PipPip
  • 26 posts
  • Denver
Posted 18 September 2004 - 05:21 AM
This is going to sound alot more complicated than it really is. The light you are trying to get to go out is telling you that you have a problem, and that you need to access the computor, and it will tell you exactly what the problem(s) is. and which part(s) are bad. It is a rather long diagnostic process, so if you want to tackle it, e-mail me directly and I can send you the diagnostic charts and trouble codes to download. FYI most states check that light as part of the emissions test.
Kerry/Roo-Builders
www.ccrengines.com/roobuilders
rubuild@aol.com
#4 NV Zeno
NV Zeno
    Elite Master of the Subaru
  • 3,108 posts
  • Ponderosa Ranch, Nevada
Posted 18 September 2004 - 09:16 AM
Yeah. What Kerry said above, he knows his stuff...he's helped me a few times with carburetor questions after instsalling one of his quality rebuilds.
#5 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 18 September 2004 - 02:34 PM
If you haven't checked the intake manifold gaskets for a leak, you should do that.
#6 subiewonkenobi
subiewonkenobi
    New User
  • PipPip
  • 17 posts
  • Nevada City
Posted 18 September 2004 - 09:42 PM
Yeah, I have a friend that has those codes, I will get them from him and check it out. I was told by the previous owner that they had it checked out (the code from the computer) and that the malfunctioning part was a part that was unavailable in the US. But I want to know for myself, besides this idle problem is driving me nuts!!! I will check the manifold too. Thanks for all your input guys! I appreciate it. And I will contact you if subieman doesn't have the codes I need.
#7 stock90
stock90
    USMB Regular
  • PipPipPip
  • 51 posts
  • Spokane, Washington
Posted 19 September 2004 - 03:02 AM
sorry if this is off topic but...
I just bought a 84 GL Sedan, has the same light on(goes on and off actually), but it passed emissions with flying colors(bought it yesterday, took it in today). might have something to do with the fact that mine has 88,000 miles on it though. I love your car, wish mine was a manual four-wheel drive (its an AT front wheel) but I can't really complain for $700. hope you figure it out.
#8 subieman
subieman
    1000+ Super USER!
  • 1,422 posts
  • Sparks, NV
Posted 18 December 2004 - 07:27 PM
I just wanted to bump this up to the top. I recently perchesed subiewonkenobi 84 wagon and I would like to figure this problem out myself. I haven't had the time to look at it too closely, I just hoped someone else has an idea what the problem is.
Thanks,
#9 NV Zeno
NV Zeno
  • 3,108 posts
Posted 18 December 2004 - 08:40 PM
What code is the computer "throwing"?
I have a Cal-spec '83 wagon (and FSM), I can translate the code if your '84 is the same. Lithia Subaru in Reno is actually pretty good at getting the older parts..stay away from Michael Hohl though, major crooks. I've had good luck at South Shore Ford(Subaru) for my Cal-spec stuff:) .
Does your part of Washoe County have emissions testing (mine doesn't)? You'll probably need to correct that prob before you can transfer title.
#10 subieman
subieman
    1000+ Super USER!
  • 1,422 posts
  • Sparks, NV
Posted 18 December 2004 - 11:07 PM
Yes I have smog in this part of Washoe. This 84 is also a calif spec. The computer does not throw any codes. I have the FSM also.... but so many factors. I just might take it in to Independent Auto to have it checked out.
#11 NV Zeno
NV Zeno
  • 3,108 posts
Posted 18 December 2004 - 11:18 PM
If you're seeking pro help, Ken and Fred are the best in these parts:) .
Cross your fingers it's something simple.
