sway bar bushing replacement
2 replies to this topic
#1 mountainbikeak
mountainbikeak
    USMB Regular
  • PipPipPip
  • 76 posts
  • anch
Posted 17 September 2004 - 11:02 AM
91' loyale, my front suspension squeaks while goving over bumps etc. I had my girl friend pust up and down on the front while Ilistened for noise, it appears to be a sway bar bushing. Has anyone replaced this before? What does it take for a job like this? thanks
#2 oobnuker
oobnuker
    Subaru Nut
  • 522 posts
  • Oxford, CT
Posted 17 September 2004 - 11:08 AM
It should be a piece of cake - but make sure you put the entire front end up in the air (both sides) otherwise the forces of once side will tweak the swaybar and cause you a lot of headaches. If everything is just hanging free it should be no problem at all.
#3 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 17 September 2004 - 11:37 AM
My bushings are cracked and crunchy too. I'd appreciate it if you could report the results if you do replace them.
