simpreza2 Posted September 18, 2004 Share Posted September 18, 2004 I have 104k on my 97 OB and I want to do all the maintenance. This is my list so far... -timing belt -2 head gaskets (they are on there way out) -waterpump -thermostat -2 radaitor hoses -4 front cam(oil) seals -new tensioner adj. Any thing else while its all apart? Thanks Jon Quote Link to comment Share on other sites More sharing options...
cookie Posted September 18, 2004 Share Posted September 18, 2004 and the crank seal myself. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted September 18, 2004 Share Posted September 18, 2004 If your doing the head gaskets , i would suggest you pull the motor out, it makes it so much easier to do the head gaskets than in the car and when it is out replace the (black) oil separator plate with the updated aluminum plate. Also replace the rear main seal would be a good idea SEA#3 Quote Link to comment Share on other sites More sharing options...
Commuter Posted September 19, 2004 Share Posted September 19, 2004 Service the oil pump. (O-ring and back plate screws.) There are articles on this. You are also getting to an age where the O2 sensor is probably getting weak. You can just let it go if you want. Commuter Quote Link to comment Share on other sites More sharing options...
