i have a 99 legacy ej22 with a 5 speed manual. I was wandering what i could do to take my car from 142 horsepower up close to 200 without going to a turbo or engine swap. And would my stock tranny hold with 200 horsepower. Any ideas for power gain would help.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
i want more horsepower(ej22)
Started by
neha3x
, Sep 29 2004 08:25 PM
3 replies to this topic
#1
Posted 29 September 2004 - 08:25 PM
#2
Posted 29 September 2004 - 10:17 PM
I'm thinknig your legacy tranny could handle 200hp, with reccomended fluid changes, and as long as your not too hard on it.
you'd need: better flow in your heads*, cams, intake work, bigger injectors, exhaust, engine management.
*Ej22 heads flow poorly. you COULD port them and do alot of insane head work, but I reccomend finding Ej20 heads. the difference between an EJ20 head and an EJ22 head is ENORMOUS. if you can find EJ20 heads it'll raise compression and also increase flow... from 9.5:1 to about 10.5:1 CR. you'd need to run premium, but at least you can get it at every pump.
with better flow, and more fuel needed, you'd want bigger injectors. not too huge, but something to compensate so you don't run lean.
And don't count on getting good gas mileage.
#3
Posted 30 September 2004 - 01:15 AM
Well, for that sort of horsepower gain, you must replace the camshafts. Standard lobe profiles will not produce 200bhp.
The transmission is going to be stressed quite a lot more. And it's the weakest part of the car, relatively speaking. 200bhp is a lot.
For sure the clutch will not hold up to this. While you have the engine out to replace the camshafts, grind the heads and fit metal gaskets, make sure you fit an uprated clutch.
New injectors would also reduce fuel delivery problems, along with a new regulator and pump.
#4
Posted 30 September 2004 - 08:37 AM
And don't forget the Chrome Moly muffler bearings and the high compression tire valves!
Go find a turbo equipped subie...
