Guest tompalushock Posted August 9, 2003 Share Posted August 9, 2003 Ok, my 83 gl has a problem with the lower vents. When i have the a/c on, the air still comes out of them, as with the defroster. When in the defroster mode, the air does not come out at all on top of the dash. I took the console apart, and all the cables seem to be together, but to get to the plastic type pulleys, it seems i would have to take the whole heater duct off, which i don;t want to do. Is there an easier way to close this vent so the air just comes out on top, and with the a./c on, out of the upper vents? Quote Link to comment Share on other sites More sharing options...
Guest electryc monk Posted August 9, 2003 Share Posted August 9, 2003 i wonder if a vacuum line cracked/broke/got loose/fell off? if the EA81 dash is remotely similar to the EA82 Dash stuffings then the lower drivers side nearest the gas pedal there is a few vacuum and temp cable parts to take a look at. Not sure if that even helps... Quote Link to comment Share on other sites More sharing options...
Guest tompalushock Posted August 9, 2003 Share Posted August 9, 2003 Well, the a/c works, air blows out of the upper vents, but it should not be blowing out of the vents below[by my ankles, correct}? same with the defroster, when i put it on, no air comes from the top of the dash, but is sure does come out strong by the bottom vents. Quote Link to comment Share on other sites More sharing options...
