can u put a ford 9 inch rear and drive train into a subaru wagon
7 replies to this topic
#1 jalappajesse
jalappajesse
    New User
  • Pip
  • 1 posts
  • pottsville
Posted 04 October 2004 - 11:59 PM
how to put a ford 9 inch rear and drive train into a subaru wagon and what would have to be done to mount the rears in place if it can be done?
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 05 October 2004 - 12:13 AM
You will have to build a sub-frame for it. And the only motor that will run that much gear would be the 2.7, unless youre going to use a non Soob V6. The biggest straight axles that have been run so far are Nissan and Yotas.
#3 carfreak85
carfreak85
    Temple of Fuji
  • 5,242 posts
  • Cascadia
Posted 05 October 2004 - 12:35 AM
Anything can be done, but how much do you want to spend on fabrication?
#4 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 05 October 2004 - 03:16 AM
You can do anything with liberal application of the hot wrench. Question is...why would you want to? The Ford 9" is very strong, but also VERY inefficient. A subaru doesn't weigh enough to need that much strength, so you trade strength against efficiency. That's why Soob folks tend to run Nissan and Yota straight axles. Don't need anything heavier. If you are just dead set on running Ford gear, why not use a Ford rig in the first place? If you just want the Subaru body...maybe look at swapping a wagon body onto a Ranger frame?
#5 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 05 October 2004 - 09:53 AM
hmm regardless of initial body and frame weight bigger tires and gearing do have a tendancy to take its toll on the lesser of axles...
granted running asuby motor with toy axles and say .. oh 38 inch tires you prolly cannot develope enough low end tourqe even with gear reduction to break em but add a v'6 or something and well anything can go wrong
myself if.when i build stuff i try and over build what i can .. just so i do not have to worry about it later
kinda like say for instance that tiny suspension bushing you replaced with a cheap stock piece... instead of the few dolalrs more beffier one .. and now yout stuck out in the middle of no where with no help and no suspension..
farfetched example prolly.. but you can see the point i think
heh if i get to do my project .. i am dreaming 2.5 ton rockwell axles multilink suspension chain box 700 r4 tranny and of course a suby heart turbo and efi of course hehe
maybe caged ifs on teh end of multilink.. it works out in my head.. not sure how it works in real world
#6 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 05 October 2004 - 02:37 PM
I'm planning on building a Brat minitruck on a Nissan truck frame. I'll be using the frame from a standard cab, the solid rearend and the front suspension. I also plan on 4 linkin the rearend and baggin it but thats after I get the GM 2.8 v6 and a 5-speed in there:D
#7 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 05 October 2004 - 04:02 PM
<--again looka t 2.8/3.0 ho cross ram injection setup i have no use for
#8 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 05 October 2004 - 04:15 PM
It can be done. You can put whatever rear end you want in there. The real question is how much time and money do you have? :-p
