sasquatch Posted October 7, 2004 Share Posted October 7, 2004 I noticed that my muffler is developing some cancer....that doesn't bode well for the rest of my piping hidden away in that shrouding. I recently had the headers off so I know they are in decent shape. Soooo....I was thinking of replacing the cats while I'm at it back to the tail pipe (I have over 200K so I figure they can't be very clear either). Can anyone tell me if there is anything keeping me from replacing the two cats under there with one high-flow cat? Where are the 02 sensors? Thanks. Quote Link to comment Share on other sites More sharing options...
northguy Posted October 7, 2004 Share Posted October 7, 2004 he only factor for replacement may be that it might be cost prohibitive. Cats are notoriously expensive and most states with emissions testing forbid replacement with anything but new parts. With 200k on the clock, do you want to drop $300+ into the exhaust? Quote Link to comment Share on other sites More sharing options...
slo5oh Posted October 7, 2004 Share Posted October 7, 2004 First off... what year is your car? I noticed that my muffler is developing some cancer.... shell gasoline? Shell is high in sulphur. It runs through your engine gets transformed into sulphuric acid and on it's way out eats holes in your exhaust. The early signs of this are holes in your exhaust tips (the small pipe sections behind the mufflers) that doesn't bode well for the rest of my piping hidden away in that shrouding. I recently had the headers off so I know they are in decent shape. Soooo....I was thinking of replacing the cats while I'm at it back to the tail pipe (I have over 200K so I figure they can't be very clear either). Can anyone tell me if there is anything keeping me from replacing the two cats under there with one high-flow cat? Where are the 02 sensors? Thanks. Replacing the 2 cats with 1 would depend on the state you are in. I would call a local smog referee and ask. As for 02s it depends. If the car is too new (last couple years) it will have 4 O2s (at about $150 each), there should be 2 in front and 2 behind the cats. If the car is a couple years old or more you have 2 and they should be in front of the cats either in or behind the headers and they are much less expensive. If you love your car take it to a smog shop and tell them what you want, if you are low budget (like me) then watch your local papers, penny saver, etc, for a "parting out" ad on a car like yours and take the entire exhaust for $50. Quote Link to comment Share on other sites More sharing options...
sasquatch Posted October 7, 2004 Author Share Posted October 7, 2004 Well, to begin with I'm in Washington, my car get's nothing but Chevron gas and it's a '90 Legacy Wagon. The price of a cat is no big deal. You can get Magnaflow universal cats off ebay for like $70. any opinions on if this will work? Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted October 8, 2004 Share Posted October 8, 2004 It's my favorite half-man, half-ape.... I gutted the cat on my 90 legacy and let me tell you it sounds BAAAD! (not good bad) The problem you are going to run into is that the front cat is basically a giant "Y" pipe. You have the two manifolds that dump into the cat but only one pipe come out. Every place I called said they would have to use a universal cat and weld up some high-dollar fancy piping. Did I mention that the o2 is in the front cat. I hope this helps.. Greg from FL Quote Link to comment Share on other sites More sharing options...
sasquatch Posted October 8, 2004 Author Share Posted October 8, 2004 That does help....sounds like if you get a good front cat and adapt the flanges you should be able to eliminate the rear....have to get a quote... Quote Link to comment Share on other sites More sharing options...
Guest Vickaroo Posted October 8, 2004 Share Posted October 8, 2004 Heck just go down to the pound and get two cats!!!!!! Place under the hood and tell the person that doing the insp. you have two cats under that hood.... Sorry I couldn't help it... Sometimes we just need a little laughter in our lives... Vicky Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted October 9, 2004 Share Posted October 9, 2004 I found out that my local chinesse restaurant gets their meat from the pound, not by the pound. MEOOOOOW...RUFF RUFF= poo poo platter. I think there is a misconception oh kidnapper of Beastie boys. What I was talling you is that the manifold and the cat are basically one piece. If you go to the following address you will see what I mean. You will notice there is a cheap universal and a direct bolt on. The direct bolt on is just that. http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&Parameters=TRUE%7C%7ECATALYTIC+CONVERTER%7C%7ENONE%7C%7EBOSAL%7C%7EDIRECT+FIT++++++++++%7C%7EFALSE%7C%7EFALSE%7C%7E529660%7C%7E1231%7C%7E099-3221%7C%7ECOMPARE+TO+ORIGINAL%7C%7E%24561.80%7C%7ESUBARU%7C%7ELEGACY%7C%7E1990%7C%7ELLT%7C%7E7.0%7C%7EEA%7C%7EO I am looking for someone who will weld up some custom pipes to remove the front cat but no muffler shop in their right mind will touch it. Reasons are: 1. $10,000.00 fine 2. Jail time 3. business shut down for minimum of 30 days. It is a federal offense. I wish I could weld, had a mandrel bender, pipe expander, a lift, some 2" pipe, an oxy/acetylene tourch, and a pipe notcher. Then I could DIM. Quote Link to comment Share on other sites More sharing options...
